2 members (UtahYork, Nick in Manitou), 46 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#68777 11/18/2006 12:01 AM
Junior Member
Junior Member
I've been searching for a while on google and the stovebolt site and I'm stumped. How do I tell the difference between an externally balanced flex plate for a 700R4 and an internally balanced flex plate? There are no numbers on the flex plate that I can find.
Brad
#68778 11/18/2006 1:21 AM
Most aftermarket plates are balanced just incase they end up going on a small block 400. There will be a metal weight welded to the plate that balances it,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#68779 11/18/2006 1:26 AM
Junior Member
Junior Member
Scott, the flex plate I have doesn't have any external weight welded to it. Every externally balanced flex plate picture that I could find that seemed to show a plate of some kind welded to it. I guess that would make the one I found was intended for an internally balanced engine.
Thanks for the reply.
Brad
#68780 11/18/2006 1:44 AM
It also could have large drill holes that are not drilled all the way through the flex plate.Material was removed on the "heavy side" to balance it.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#68781 11/18/2006 3:02 AM
Junior Member
Junior Member
On this particular flex plate all the holes are symetrical and there aren't any partial holes. I'm fairly certain its for an internal balanced engine. I'll look for a balanced flex plate when I stop in at my favorite salvage yard next week.
Brad
#68782 11/18/2006 11:11 PM
Riding in the Passing Lane
The external balanced flexplate is not for the trans. The 400 small block & 86 up small blocks must use a flexplate with balance weights. They do not use the same one. No other small block should use the weighted flywheel regardless of trans. There are variations for big blocks also.
1972 Chevy c10 Cheyenne Super
#68783 11/19/2006 2:33 PM
Junior Member
Junior Member
Wrenchbender, I'm building a 383 stroker which is why I'm looking for a 400 flex plate. I ran across a flex plate and it had no numbers so I wanted to make sure how to identify the differences.
Brad
#68784 11/19/2006 4:34 PM
I think I would just get a new one. There is variations in the weight & position of the weight. If its not right you will have horrible vibrations.
