0 members (),
191
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#68743 11/16/2006 11:01 PM | Joined: Nov 2006 Posts: 25 Junior Member | | Junior Member Joined: Nov 2006 Posts: 25 | Will I be able to pull my stovebolt from my 66 stepside with the 3 speed transmission attached? I pulled the radiator and fan. I would rather not pull the radiator support unless it is no big deal to do so. Will it clear if I pull as a unit?
Of the 4 bolts holding the trans to the clutch housing the 2 bottom bolts are broke off, even with the case, it seems as they are guide pins put guess they are broken bolts,
The trans is "welded" on.
I was thinking of putting a strap on the tail of the trans and another on the rear axle with a come along in the middle, applying rearward pressure and tapping the trans, I have been applying penentrating oil. Any other suggestions if I can not pull as a unit would be appreciated.
Thanks much. | | |
#68744 11/16/2006 11:08 PM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I'm not familiar with the "newer" trucks but I'll bet the bolts that appear broken off have the heads inside the bellhousing. | | |
#68745 11/17/2006 3:08 AM | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | You can pull it out as an assembly as that is how most engines with automatic transmissions are removed/installed. You will probably have to use a tilt sling to get it at the right angles to clear as your removing it. As Cletis stated, remove the lower cover and remove the bolts from inside the bellhousing. Fred
#68746 11/17/2006 3:39 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I agree with Cletis, the heads to the lower trans bolts go from the inside of the bellhousing into the trans. Pull the flywheel cover and have a look inside, Scott | | |
#68747 11/17/2006 8:19 PM | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | i am not familiar with your model, but we pulled lots as one piece. hook the engine by head bolts or something stronger than cast manifolds, the trans end will drop. we used a rolling floor jack under the tail. it kept the trans off the floor as well as providing adjustment as the assembly climbed out of the engine bay. pull the hood.
"It ain't a truck if you can't hose out the cab."
#68748 11/17/2006 9:14 PM | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | i just pulled one salvage that way... but youll have to remove the crossmember under the transmision.(bellhousing) ..or remove the top cover on the transmission or the tower for the shifter wont clear the floor inside the cab... i notched the cab floor with a zip gun to get it out..since truck is being hauled off for scrap....
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
#68749 11/24/2006 10:19 AM | Joined: Nov 2006 Posts: 25 Junior Member | | Junior Member Joined: Nov 2006 Posts: 25 | Thank-you. Sure enough the heads were on the inside. Thanks | | |
