| | | Forums66 Topics128,114 Posts1,056,283 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#68735 11/16/2006 9:17 AM | Joined: Feb 2006 Posts: 15 Apprentice | | Apprentice Joined: Feb 2006 Posts: 15 | Has anyone ever changed their oil pan gasket out without taking out the engine ????? I have a 250 six in my truck would like to change the leaky old thing. I looked and I do think it could be done , but thought maybe if someone did it what problems if any did they have.... Thanks guys.... | | |
#68736 11/16/2006 5:35 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I had to remove the frame crossmember & flywheel cover to get mine off (38 216). When you go back on with the pan use two or three 1 1/2" bolts with the heads cut off to help with the alignment. Use bolts the same size & thread as the stove bolts holding the pan on. Put one or two finger tight on each side of the pan. Use these as alignment guides to position the pan. Put the rest of the fasteners in but not tight. Remove the alignment bolts, install the fasteners in those holes and tighten all. Good luck.
#68737 11/16/2006 11:16 PM | Joined: Oct 2002 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 77 | I replaced the oil oan gasket in my 66 C-10 with the 250 ci, I had to raise the front of the engine about 4 inches so as to clear the cross member, I removed the motor mount bolts and used an engine hoist to lift it. | | |
#68738 11/17/2006 7:30 AM | Joined: Feb 2006 Posts: 15 Apprentice | | Apprentice Joined: Feb 2006 Posts: 15 | Thanks guys now I know it can be done... | | |
