9 members (treegrower, 68ironhead, GRNHydra, Nhluvstruck, 55shaker, MickeyP, elhippie64, David Bush, 1 invisible), 43 guests, and 1 robot.
Topics128,090
Posts1,056,016
Members48,430
#68735 11/16/2006 9:17 AM
Apprentice
Apprentice
Has anyone ever changed their oil pan gasket out without taking out the engine ????? I have a 250 six in my truck would like to change the leaky old thing. I looked and I do think it could be done , but thought maybe if someone did it what problems if any did they have.... Thanks guys....
#68736 11/16/2006 5:35 PM
Ex Hall Monitor
Ex Hall Monitor
I had to remove the frame crossmember & flywheel cover to get mine off (38 216). When you go back on with the pan use two or three 1 1/2" bolts with the heads cut off to help with the alignment. Use bolts the same size & thread as the stove bolts holding the pan on. Put one or two finger tight on each side of the pan. Use these as alignment guides to position the pan. Put the rest of the fasteners in but not tight. Remove the alignment bolts, install the fasteners in those holes and tighten all. Good luck.
#68737 11/16/2006 11:16 PM
I replaced the oil oan gasket in my 66 C-10 with the 250 ci, I had to raise the front of the engine about 4 inches so as to clear the cross member, I removed the motor mount bolts and used an engine hoist to lift it.
#68738 11/17/2006 7:30 AM
Apprentice
Apprentice
Thanks guys now I know it can be done...
