| | | Forums66 Topics128,056 Posts1,055,804 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 65 | It's been over ten years since I sand blasted anything. Went to the Home Depot and they didn't have it. Before I go calling all around town, where do you all buy your silica sand? Tractor Supply has some fancy stuff, but it's pretty expensive, and I'm just cleaning up an old intake manifold, so silica sand would do fine. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | depending on what you use to do the blasting. I buy mine at the local concrete place. You know, the place that has the cement mixing trucks and sells block ect.
I can buy a 50 lb bag for less than $350 and it is BLASTING SAND. I can get it in Fine, extra fine, and medium. The good part is true blasting sand helps keep down the clog ups.... true blasting sand is "sized" and its cheap.
I can't afford the Black Beauty from Tractor Supply. At about $9 a bag it isn't worth it. Yes its aggressive on bad stuff but so is the fine sand unless you have used it until its old and turned to powder. I do some pretty rough stuff but the bag of Black Beauty($$) and the bag of Medium sand I keep has yet to be opened. Just a thought.... if using in a blasting cabinet I only put in a half bag at a time and change it regularly as it gets contaminated. And as Joe points out. Don't breath anymore of the stuff than you have to! | | | | | Joined: Nov 2008 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 65 | Thanks for the tips guys. I hadn't heard of silicosis before. I'll be sure to wear a respirator and ear plugs along with he eye protection.
| | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | Silica sand is getting harder to find, least around here. The brick and stone place in Springfield quit selling it. When I was in West Plaines I found some at a local building store.
Regular sand, available in different grits, works but not as well as silica in my opinion.
Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Apr 2009 Posts: 349 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 349 | We get a few kids together and go to a local river, like the Missouri or Niobrara and sift sand, the kids have a blast doing it (no pun intended)! That sand works better than bought sand and lasts 3 times as long, not sure why, but it does, and its free!!!!! | | |
