0 members (), 140 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#684704 10/10/2010 6:17 AM
I found this chevy c65 at the scrap yard this week, http://s1105.photobucket.com/albums/h357/BlueAndSilverChevy/ , the guy said he wants $500 for the truck without the motor, he said it was a 366 but im not really sure... He said $800 for the truck and motor, at a closer look today i saw some concerns, 1 no brake booster, 2 no radiator, 3 rust in the rockers.... what should i offer? I was thinking 350 for just the truck, and 600 for the truck and motor, what do yall guys think?
I say its worth scrap price and not much more, so $500-600 with engine. if you want to put it back on the road I'd look for a better truck.
If you deal on a trashed-out piece of junk like that, invest in a big jar of Vaseline! It's already been picked over for all the good stuff. I wouldn't offer more than $250.00 for the whole rig, unless he's willing to let me hear the engine run, do a compression test, etc. He's already made his initial investment or close to it by selling bits & pieces, so whatever you're willing to give will be pure profit for the junk man. What do you intend to do with it once it's yours?
Moderator
Moderator
2 Offline
After looking at the pictures, no more than scrap value and then use it for a parts truck.
2-Ton
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
2-Ton #684770 10/10/2010 3:53 PM
I would figure it this way.....Take the weight of that thing times the rate paid per pound at the salvage yard.
That's if they will accept it as is. Some don't want tires, fluids, glass,etc.
That figure minus the cost of getting it to the salvage yard should produce what that thing is worth, unless there is some component still on it that has great value.
Dan
Remember your freedom - US Veterans provided it.
101st Screaming Eagles
0
0 Offline
You can buy much better trucks, complete and running, of that size out here on the West Coast for less than $2000. that's a parts truck. Joe
Where are you in the US? I would bet that we could find something, in a lot better shape, for a lot less money, that runs and drives.
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
PapaJ #684905 10/11/2010 2:27 AM
Well i am 17 years old, and don't know what to look for in the c60's.. I have a 84 k10 myself. I think if i got another cab from the guy, i don't see how i could go wrong. Is the brake booster and radiator that big of a deal? If it was missing the transmission i would understand... Im not trying to be rude, i just don't understand what's so bad about it? Thank y'all so much for the info! I am in Cumming Ga, PapaJ
If you look at my '53 in the Gallery that is a running truck that I purchased for $800.00. Then add $300.00 for the bed. Now you can see why we say you can do better.
1953 Chevy Two-Ton
PapaJ #685045 10/11/2010 2:33 PM
Well since yours is a 53 will there be that much difference in price??
JMHO, the 53 is worth double the 65 in like condition.
Now you went and got me in a fight with the 65 owners grin D:
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
My work is done here, now to go get some coffee!)
1953 Chevy Two-Ton
There are a couple of really big items to consider. First, a C-60 was a commercial truck, not a pickup, so parts are going to be scarce and expensive. There's no sense stacking the deck against yourself by buying a non-running junkyard dawg that's had expensive parts scavenged off of it. Second, just why was it scrapped in the first place? If you discover there's major damage to the running gear, transmission or rear end for instance, you could get into twice your initial cost with the purchase of one item. The brake system will have to get a total overhaul, as those parts deteriorate rapidly from non-use. I'm very concerned about the 2-speed rear axle shifter being missing- - - -junk yard operators don't allow pieces like that to be scavenged off a good, serviceable item, so you'd better count on having major rear end problems. The cab is trashed- - - -a real rust bucket, and swapping to another cab is a huge effort.
After you get it fully restored, what do you intend to do with it? It's expensive to license, and just buying tires will be a major expense. Do you have a commercial use for a 2-axle tractor without a 5th. wheel? About all it would be good for would be as a mobile home transporter, or something similar, unless you equip it to haul semitrailers again, which was probably its original purpose. Without air brakes, even if it was equipped for a semitrailer, its use would be limited. Us mechanics are eternal optimists, but we usually try to heal the sick, not raise the dead!
I would agree that a '53 would be worth more than a '65. If it were a '53 in the same shape for the same pricing then you would be getting a fair deal...if the engine was indeed good. Seeing as how it is a newer large truck they are not worth nearly as much. If you simply wanted a work truck and it ran...had a radiator...and brakes...then it would probably be O.K. This would not be a good truck to try and restore though as it is missing so much of the interior, missing brake components, and has no radiator. I would say unless you find a great deal you are looking at a couple hundred to replace the radiator alone.
As a parts truck that would be a decent price as it is basically what scrap value is. The $300 for the engine though I would want some sort of guarantee that it is actually good. It looks like the front plug on drivers side may be missing as well...or wire is just off. If plug is out I would really question the engine.
Just noticed that it is missing the shifter for the 2 speed rear as well. That will be another $50(good) to $150.
1946 Chevy OS 1.5ton, 1955 GMC 3100, along with other various IH,Ford,Nash,MGB,.....
