5 members (TUTS 59, WICruiser, Greg_H, GMCJammer51, treegrower), 123 guests, and 1 robot.
Topics128,105
Posts1,056,545
Members48,448
Y
Y Offline
Anyone have any feedback on them? I have a 57, and got the kit.But am having fitment issues. 350engine/tranny. Tranny hits frame crossmember,can't lower rear of trans enough to fit the new crossmember.Also,the engine must drop about an inch to line uo with new engine mount,which would compound the tranny problem even more.Hope this makes sense. Called CPP,which is where the kit came from, but they weren't any help. Any other decent fitting conversion kits available?
I have a 59 short bed with a 383 small block and a Art Carr 400 tranny with a Gear Vendor overdrive. The front engine mount will fit in the frame channel straight across and the tranny has about a 4" drop from the frame channel.
1940 Chevy 1 1/2 ton, 1959 Chevy 1/2 ton, 1966 Chevy C20.
I can explain it to you but I can't help you understand it.
Y
Y Offline
Did your tranny hit the frame crossmember?
I am so sorry that I did not tell you, but you must remove the crossmember. Note the you will need to weld the tubular pipe to the tie downs and then bolt to the frame.
Y
Y Offline
Excellent. Thanks for checking in!
Removal of that cross member may require cutting it into. On my 58 I could not get it out in one piece.
Make sure everything is where you want it before you weld. drill a hole through the tubular pipe and tie downs and put in a bolt to keep everything aligned as you bolt it to the frame.
When it all fits do the welding.
1954 Chevy Half-Ton
More pix on Shutterfly
More pix on Photobucket
1958 Chevy 1/2-Ton Stepside
"Time's fun when you're having flies." ~~ OLD FROG
