5 members (jmoore, fonz8261, gswbbc, Lugnutz, Dennys28), 78 guests, and 3 robots.
Topics128,031
Posts1,055,434
Members48,422
#68559 11/14/2006 2:11 AM
The right side U bolt holding my axle to the fame rusted through and the control arm (which was very rusted) bent as the whole thing hit the road. I got a tow back home and want to replace both control arms, Question is… do I go with new ones from the catalogs or can I by used ones and if so which years will work on my 66 C10?
#68560 11/14/2006 3:22 AM
Good luck finding usable used ones, muchless being able to remove them from a donor in one piece. I would opt for new ones or even performance arms if money would allow it,
Scott
BTW, I think 63-66 C10's are all the same although LMC lists them for 60-66 C10 and C20 under the same part number.
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#68561 11/14/2006 2:15 PM
Thanks for the tip... I'm new at restoring anything let alone something as cool as my 66! Thanks again
#68562 11/14/2006 5:43 PM
Junior Member
Junior Member
48bigtrucks is absolutely right,when it comes to suspension parts always go new, todays new materials are much more durable and most are available at your local parts shop.
Those who fail to plan, plan to fail....
