9 members (55shaker, cmayna, Wally / Montana, 2-Ton, GusG, FAST55, Phak1, 3B, 1 invisible),
62
Mod | | | Forums66 Topics128,185 Posts1,057,281 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 51 | I have a 55 second, 3600 with 8 lug wheels. I read somewhere (probably here) that the 80's Ford Econoline rims are a good step away from the split rims. The only followup change would be to change the tie rod ends for the modern one ton parts. I have located some 1988 Econoline E350 8 lug rims with LT-215/85 R 16 tires. I have also located some Chevy steel wheels from a 1995 1 ton van. Which is the better choice and why? Is there another stock steel wheel that might be recommended? I would like to get away from the spit rims so I can use some decent radials.
Love the classics! 1954 3100 1965 Mustang vert
| | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | I would choose the one that fits, unless you'd be unhappy with saying you have ford wheels on your truck.
A wheel is a wheel except for the size and offset and the ability to accept a wheel cover/hub cap.
What I'm saying is, if the bolt pattern were the same could anyone tell the difference between a chevy and a mopar wheel. Only those with sharp eyes that know wheels.
Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Sep 2010 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 51 | Dan - It doesn't matter to me what the brand is either. I am hoping I can get some input as to what others may have found to work well as a more modern wheel replacement. I thought I had seen where the Econoline rims of the 80's were a good replacement. Someone else mentioned he thought the Econoline rims went from a 16.5 to a 16 rim in the mid 80's. Then in 1990 they changed it all again with the backspacing, which makes it a mismatch for the original suspension and brakes, and tie rods. Any suggestions??
