1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#68523 11/13/2006 8:42 AM | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Does anyone know the differences on the frame width & wheel openings & wheel base if any from a 3100 and the 3600 Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | |
#68524 11/14/2006 1:32 AM | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Don't have my books with me, but in general, the 3100 frame is tapered all the way back, and the 3600 frame matches the 3100 from the front to somewhere under the box, then the rails are parallel. Wheel openings are the same, as they use the same fenders. Wheel base is (I think) 9 inches longer on the 3600.
Hope this helps.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
#68525 11/14/2006 10:20 PM | Joined: Jul 2006 Posts: 11 Junior Member | | Junior Member Joined: Jul 2006 Posts: 11 | THE WHEELBASE ON A 3100 IS 116".Wheelbase on 3600 is 125 1/4. My book says 3100 has 46 1/32 max frame width and 3600 has 36 max frame width. | | |
