Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (klhansen), 136 guests, and 10 robots.
Topics128,281
Posts1,058,470
Members48,490
#68449 11/11/2006 6:10 AM
I know there are a bunch of you guys here that have built an AD truck. I need a rearend and would rather not pay the $$$ for a new nine inch Ford. Also I would rather not troll the junk yards for just the right mix in length and durability, be it a 10 inch chevy or whatever. Therefore if someone could tell me what brand, model and year they have used with success I would really appreciate it. BTW I will use leaf springs and drum brakes on the rear.
~Jim
#68450 11/11/2006 6:37 AM
I have a 10-bolt Chevy from a '73 Chevelle wagon under my '55 1st GMC. Not sure I'd use one of those under a 3/4-ton if I really wanted to haul a load with it, but under my 1/2-ton Suburban it works great.
#68451 11/11/2006 6:51 AM
I
I Offline
Hey Big Chev, my '53 3600 has a Dana 60(8-lug)out of a '68 Ford. Width is real close to the original. Had to move the spring perches and shock mounts,adapt the brake line and drive shaft.Also needed big center hole wheels.Ratio is 3:70, much better than the stock 4:56 and I believe could be changed out to most any ratio, or posi. $$$
#68452 11/11/2006 8:47 AM
id get one from a 3600 chevy should bolt right in
#68453 11/11/2006 5:13 PM
Will be running a SBC and 700-R4.
~Jim
#68454 11/12/2006 8:00 AM
ive got a 383 with auto in one of my trucks and it has a caddy rear with lowering springs but it also has disk brakes and disk up front not on the road yet
#68455 11/15/2006 1:03 AM
I did the same as Ironhead, I used a '79 Ford 250 (Dana 60)
with 8 lugs. Had to do the same as Ironhead on the mods.
(b-line,drive shaft, shock perch etc.). It is a little wider than the
original unit so I had the front rims reversed out 2" to
compensate for the tracking ! You can see a picture of
it in Classic Truck Mag. (Jan. 2007 / page 86). That will give
you an idea of what it will look like. The ratio is 3:54 &
Randy's Ring & Pinion makes a posi for it (had it installed
this last summer) ! Seems like a bullet proof unit to me !
Hope this helps, keep us posted on what you do !
'53 GMC "Ranger"
#68456 11/17/2006 8:37 PM
From 1946-1972, all of the 3/4 and 1 ton axles have interchangable ring and pinion parts.
