| | | Forums66 Topics128,016 Posts1,055,337 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#6838 02/28/2003 12:51 AM | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | I know that the '47 - '55.1 VIN plate is located in the front of the driver side door jam, however, whould that VIN be stamped on the frame? If so, where? I need to have it verified by DMV. The VIN plate is missing. Thanks. | | |
#6839 02/28/2003 12:54 AM | Joined: May 2000 Posts: 234 Shop Shark | | Shop Shark Joined: May 2000 Posts: 234 | No VIN stamped on the frame, until '57 I think.
Harbor Freight sells a number stamping kit, $15. Good place for it would be the top rail of the frame in front of the steeing box. Problem solved.
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
| | | | | Joined: Nov 2002 Posts: 21 Apprentice | | Apprentice Joined: Nov 2002 Posts: 21 | C duty has the door ID plates, order stamp and put it on shhhh the bmv will never know. | | | | | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | Thanks guys, but the PO lost the title and no vin plate. The license plate is not in the DMV computer. So I need to go another route. :confused: | | | | | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | Seon, My '51 GMC 350 series (formerly mine) truck was built (Oakland) and stayed in CA. all it's life. It is VIN'ed using the original engine's serial #. Apparently, this was typical at that time.
The door post tag was never removed or altered in any way (imagine that, OCK!)
Be that as it may, DMV refused to change the paperwork to reflect the serial # on the door post (I wanted it changed, just in case I had to pull the motor out, I had a 270 waiting to go in).
Otherwise, get a moving permit, have it weighed and all the other inspections done. They will issue you a new VIN # tag and stamp it on the truck.
I know, that sucks; but welcome to California :rolleyes:
*** GMC ***
| | | | | Joined: May 2000 Posts: 234 Shop Shark | | Shop Shark Joined: May 2000 Posts: 234 | You could also pursue a "Salvage Title". Requires $50 and a mechanical inspection by the DMV. You will need a bill of sale.
-Boyo
| | | | | Joined: Feb 2003 Posts: 25 Member | | Member Joined: Feb 2003 Posts: 25 | I do not know how they do it in Cal, but in Georgia they would use the original eng number to place a number on the body. If it was not available I could say that it is homemade with a frame and body from different autos and a later motor then apply for a title and register it. How do they do autos that are built from scratch? | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | In Missouri, there is an area on the title application for "homebuilt" vehicles. No idea what it entails, just that the box is there. | | | | | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | Originally posted by gmc248: Seon, My '51 GMC 350 series (formerly mine) truck was built (Oakland) and stayed in CA. all it's life. It is VIN'ed using the original engine's serial #. Apparently, this was typical at that time.
The door post tag [b]was never removed or altered in any way (imagine that, OCK!)
[/b] Wait, there is a engine plate there in the door jam. Is that what they'll use, the engine number as the vin? If so, I'm good to go.  | | | | | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | No, the number on the engine, next to the distributor and stamped into the block. Should be something like "A228XXXXXX"
*** GMC ***
