2 members (baldeagle, TPR57C), 62 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#6838 02/28/2003 12:51 AM
I know that the '47 - '55.1 VIN plate is located in the front of the driver side door jam, however, whould that VIN be stamped on the frame? If so, where? I need to have it verified by DMV. The VIN plate is missing. Thanks.
#6839 02/28/2003 12:54 AM
No VIN stamped on the frame, until '57 I think.
Harbor Freight sells a number stamping kit, $15. Good place for it would be the top rail of the frame in front of the steeing box. Problem solved.
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
#6840 02/28/2003 1:01 AM
Apprentice
Apprentice
C duty has the door ID plates, order stamp and put it on shhhh the bmv will never know.
#6841 02/28/2003 5:01 PM
Thanks guys, but the PO lost the title and no vin plate. The license plate is not in the DMV computer. So I need to go another route. :confused:
#6842 03/01/2003 1:05 AM
Seon,
My '51 GMC 350 series (formerly mine) truck was built (Oakland) and stayed in CA. all it's life. It is VIN'ed using the original engine's serial #.
Apparently, this was typical at that time.
The door post tag was never removed or altered in any way (imagine that, OCK!)
Be that as it may, DMV refused to change the paperwork to reflect the serial # on the door post (I wanted it changed, just in case I had to pull the motor out, I had a 270 waiting to go in).
Otherwise, get a moving permit, have it weighed and all the other inspections done. They will issue you a new VIN # tag and stamp it on the truck.
I know, that sucks; but welcome to California :rolleyes:
*** GMC ***
#6843 03/01/2003 1:54 AM
You could also pursue a "Salvage Title". Requires $50 and a mechanical inspection by the DMV. You will need a bill of sale.
-Boyo
#6844 03/01/2003 5:58 AM
I do not know how they do it in Cal, but in Georgia they would use the original eng number to place a number on the body. If it was not available I could say that it is homemade with a frame and body from different autos and a later motor then apply for a title and register it. How do they do autos that are built from scratch?
#6845 03/01/2003 7:23 AM
In Missouri, there is an area on the title application for "homebuilt" vehicles. No idea what it entails, just that the box is there.
1954 GMC De Luxe COE
#6846 03/01/2003 3:10 PM
Quote
Originally posted by gmc248:
Seon,
The door post tag [b]was never removed or altered
[/b]
Wait, there is a engine plate there in the door jam. Is that what they'll use, the engine number as the vin? If so, I'm good to go. grin
#6847 03/01/2003 6:23 PM
No, the number on the engine, next to the distributor and stamped into the block. Should be something like "A228XXXXXX"
*** GMC ***
