4 members (Wayne67vert, Forty9, 55shaker, 1 invisible), 115 guests, and 3 robots.
Topics128,090
Posts1,056,369
Members48,442
Junior Member
Junior Member
Can anyone tell me the last year the inline six was available.
I am looking to buy one to bolt into my 1966 stepside.
If made into the eighties, is it easy enough to take the smog stuff off the motor?
Thanks for any info.
1986. The last ones were equipped with a Rochester 2SE 2 barrel carb. They were used in 1 ton crew cab and step vans mainly. I don't see any problem with removing the smog stuff if you set up the cam/ignition/feul system to be able to run without it.
Bill Burmeister
gm makes an i/6 called the atlas and it is the bravada and other vehicals. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Oh,yeah, I forgot about the Atlas. Feel kind dopey forgetting that one, seeing how my parents have an Envoy. Good engines. GM was toying around with making a crate version of it for hot rodders, similar to the Ramjet engines with the self contained ECM for the feul injection. Not sure why they never made it available.
Bill Burmeister
Junior Member
Junior Member
Thanks for the info
Check some reputable salvage yards for a 250. They are pretty common, and should not be too expensive. Also, it is better to get one from a truck rather than a car.
I bought a good 250 out of a 1970 C-20 for $200.00 several years ago when I was living in Connecticut. It was easy to install in the 1966 C-30 that I had at the time.
