| | | Forums66 Topics128,204 Posts1,057,294 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 320 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2008 Posts: 320 | I've been looking for a new driveshaft carrier bearing for my 1 ton panel. I've found listing for a couple, but both say "not for suburban or panel".
Does anyone know what the difference would be between a 1 ton panel and a pickup?
I'm also posting this in tons of fun. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 1951 1-tom Panel?
The carrier bearing would certainly not be for a 1951 Suburban - 1/2 ton Suburbans did not need/use a carrier bearing.
| | | | | Joined: Feb 2008 Posts: 320 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2008 Posts: 320 | 1951 1-tom Panel?
The carrier bearing would certainly not be for a 1951 Suburban - 1/2 ton Suburbans did not need/use a carrier bearing. Yes I know that, just saying what the catalogue said. Thanks anyway. | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | Make sure you see a picture of what you are ordering. A carrier bearing is inside the rear end. What you are looking for is a center bearing and it is a very common part. | | | | | Joined: Feb 2008 Posts: 320 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2008 Posts: 320 | Make sure you see a picture of what you are ordering. A carrier bearing is inside the rear end. What you are looking for is a center bearing and it is a very common part. They are listed as a carrier bearing when you look them up. They are sometimes also referred to as a sling bearing. At any rate, they are common, but I can't find a listing for one for a 3800 panel. Any help would be appreciated. Meanwhile I am going to pick up my old one from the driveshaft shop and take it and my calipers to a local truck parts supplier and see if I can find a match or something that will work. Thanks
