3 members (rfs56trk, Dave1234, elhippie64), 103 guests, and 4 robots.
Topics128,203
Posts1,057,286
Members48,467
I've been looking for a new driveshaft carrier bearing for my 1 ton panel. I've found listing for a couple, but both say "not for suburban or panel".
Does anyone know what the difference would be between a 1 ton panel and a pickup?
I'm also posting this in tons of fun.
1951 Chevy 1-Ton Panel
Pictures of the restoration on Photobucket
RIP good friend.
1951 1-tom Panel?
The carrier bearing would certainly not be for a 1951 Suburban - 1/2 ton Suburbans did not need/use a carrier bearing.
1951 1-tom Panel?
Yes I know that, just saying what the catalogue said. Thanks anyway.
RIP good friend.
Make sure you see a picture of what you are ordering. A carrier bearing is inside the rear end. What you are looking for is a center bearing and it is a very common part.
They are listed as a carrier bearing when you look them up. They are sometimes also referred to as a sling bearing. At any rate, they are common, but I can't find a listing for one for a 3800 panel. Any help would be appreciated.
Meanwhile I am going to pick up my old one from the driveshaft shop and take it and my calipers to a local truck parts supplier and see if I can find a match or something that will work.
RIP good friend.
