| | | Forums66 Topics128,269 Posts1,058,399 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#68240 11/06/2006 8:42 PM | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | I've got a 53 truck in original condition ( http://www.nelsonorgel.se/en/om/truck.html)with a few small problems. One of the small problems is a cracked block, just a little crack on the driver's side where the oil line runs through. It leaks a few drops of coolant but otherwise runs just fine, but I expect that sooner or later I've got some work to do. I've tried a number of sealants without success. Some local motorheads say I might get this crack welded, others say no. I think it is a shame to replace the original engine. Anyway, here is a specific question: I rebuilt the head a year ago, new valves and seats, the engine runs like a clock. I am tempted if I have to replace the motor to go with the 235, but I wouldn't mind keeping the head from the 216. I expect this is a stupid question, but is it possible to use the head from the 216 on a 235? Any other bright ideas about how to nurse my old 216 along? So far I have no problems with coolant in the oil. I've gotten great advice here before, looking forward to some more! Anyone got an old 216 block they want to send me? It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | |
#68241 11/06/2006 8:54 PM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Here is the fix and it can be done with the engine in the vehicle, most of the time. Drill a series of holes the distance of the crack, tap the holes with machine thread and install machine screws. These holes you dill need to be almost touching each other. Then with all the screws in place grind off the heads and weld them together. I have seen an old machinest do this 3 times, it worked all 3 times.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | |
#68242 11/06/2006 9:27 PM | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | Thanks Toyvo, I'll print this out and save it till I feel like doing some work. Somehow I posted this question twice, don't know how, and didn't see the other similar posting about the 235 head. Whatever. I'm willing to try welding the block, the worst that can happen is that I wreck a cracked block. Oh I suppose I could burn up the truck too. Karl It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | |
#68243 11/07/2006 1:59 AM | Joined: Apr 2003 Posts: 27 Apprentice | | Apprentice Joined: Apr 2003 Posts: 27 | organ builder--- For easy repairs like you need I recommend K&W BLOCK SEALER. Just go by directions Strictly and it willwork. I have used it 4 times succesfully. Good Luck , 50 chevy 3100, Bob
rrf
#68244 11/07/2006 3:21 AM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I expect this is a stupid question, but is it possible to use the head from the 216 on a 235? That is not a stupid question. A head from a 216 should work on a 235 ONLY IF the 235 is a 1953 or earlier, low-pressure 235 engine. Check out the head-bolt patterns on this page. | | |
#68245 11/07/2006 5:13 AM | Joined: Nov 2002 Posts: 59 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Nov 2002 Posts: 59 | Let me add this to the text. The only 235 blocks that a 216 head will fit are the 235 blocks from 1941-1949. The 1950-52 235 heads will only work on those years. The 235/261 engine blocks from 1953-1962 can all use a common head. There are some differences.
The 1953 235 heads use the earlier 216 style valve cover.
The 1954-62 heads have 4 bolts that hold valve cover on at the sides of the cover. The 261 heads have steam holes drilled to accommodate the Siamesed cyls | | |
#68246 11/07/2006 5:55 AM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Warren,
Thanks for the correction/clarification.
Tim | | |
#68247 12/31/2006 7:55 PM | Joined: Dec 2006 Posts: 184 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 184 | Simply a testament to the information that has been posted here already: my 39 has a 1948 235 babbit banger with a 1953 216 head. It worked great for over 10 years until I recently managed to bend some valves and push rods. | | |
#68248 12/31/2006 8:08 PM | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | That block leak is common on the older 216s but I don't know about yours. The cause is usually corrosion in the water jacket. Many people have used a JB Weld type product with great success.
39AZ, start a separate thread here on your problem and I am sure you will get a lot of responses. | | |
#68249 12/31/2006 10:25 PM | Joined: Feb 2004 Posts: 29,947 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,947 | Let me add a "me too" to the suggestion about patching the leak with epoxy. The pressure in the cooling system is so low on one of the old 216's that you won't need a pressure-tight seal like on a newer engine, and welding the block will require a complete teardown of the engine, prteheating, peening, post-heating, and a lot of other monkey motion, and it still might crack beside the weld. The "sewing" procedure with the threaded plugs works best with specially designed threaded, tapered cast iron plugs, and the holes need to overlap to work properly. Drill & tap one hole at a time, thread the plug into place, cut it off, and then drill the next hole overlapping a little.
The epoxy fix can be done with the engine in place, by simply sandblasting the cracked area with a portable sandblast gun, blowing the dust away, and then spreading a liberal coat of epoxy over the crack. Be sure to drain the coolant first. Before it hardens, press a piece of 40 grit sandpaper onto the patch to simulate the rough surface of the cast iron. The repair will almost disappear, especially after it's painted. Jerry
#68250 01/01/2007 4:07 PM | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | The crack can grow from the ends. A fix for this is to drill a small hole at the end of the crack before repairing. both ends. We nickle welded a crack in a irrigation pump engine. ground the crack and welded.
"It ain't a truck if you can't hose out the cab."
#68251 01/02/2007 8:04 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | The block on my '40 has been cracked in that same place for over 20years , I put some "chemi weld" in it and all has been ok , cheap and quick , a little crude , the crack has grown several inches in that time but the chemiweld stops the leak, but its still an effective daily driver. | | |
#68252 01/02/2007 2:27 PM | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | Now I see a new few posts to my older posting, so I will add a few words of my own. The solution that Tovyo describes with the machine screws would still be a hassle with the motor in place, I'd have to pull the steering shaft and the exhaust manifold, and to top it off the crack starts right at the oil line pass through hole at the back of the oil pump. So in any event I would have to replace the oil line too and retap those threads after the welding etc. I feel more for doing the quick epoxy fix, at least until it is time for the major motor work that is on the horizon. Maybe it is a good idea to drill out the end of the crack first to stop it from growing, will this help with the epoxy fix or only with a weld? It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | |
#68253 01/02/2007 5:30 PM | Joined: Feb 2004 Posts: 29,947 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,947 | Stop-drilling thje crack is a good idea no matter how you choose to repair it. Just be sure you find the end of the existing crack before you drill. Jerry
