3 members (Hotrod Lincoln, dt235sd, klhansen), 111 guests, and 2 robots.
Topics128,127
Posts1,056,679
Members48,452
I looked inside the door last night, down through the window opening and I saw rust further up inside the door. It doesn't look bad. I'm guessing more than one person has dealt with this. Can I get some ideas? I'm thinking Dremel tool with wire brush.
just shoot some rust converter/encapsulator in there [then paint or not], it's real unlikely to be more than surface rust about as bad as sunburn, will never cause problems - where you should really use that treatment is at the bottoms where any condensation or leakage can collect, and make sure the drains are open and kept clear
I will do that as soon as I replace the door bottoms. They are SHOT! I want to start on them in the next couple of weeks. Hopefully not months.
