| | | Forums66 Topics128,175 Posts1,057,056 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | I looked inside the door last night, down through the window opening and I saw rust further up inside the door. It doesn't look bad. I'm guessing more than one person has dealt with this. Can I get some ideas? I'm thinking Dremel tool with wire brush. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | just shoot some rust converter/encapsulator in there [then paint or not], it's real unlikely to be more than surface rust about as bad as sunburn, will never cause problems - where you should really use that treatment is at the bottoms where any condensation or leakage can collect, and make sure the drains are open and kept clear
Bill | | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | I will do that as soon as I replace the door bottoms. They are SHOT! I want to start on them in the next couple of weeks. Hopefully not months. | | |
