1 members (TooMany2count), 81 guests, and 4 robots.
Topics128,126
Posts1,056,354
Members48,441
#68173 11/04/2006 7:55 AM
I don't know if this has been discussed here or not, but I believe if it has not it is worth mentioning. I ran across an article about the new oils that are lacking zddp, zinc dithiophosphate, an additive that is important in protecting against extreme pressure friction in engines, specificially the type encountered by a camshaft with flat tappets. The complete article is at: www.ttalk.info/zddp.htm.
I believe there may be something to this, and for those of us with engines that do not have roller camshafts, it would be prudent to at least get more information about this to avoid trouble in the future.
#68174 11/04/2006 11:41 AM
#68175 11/04/2006 3:45 PM
Shell Rotella T SAE 30 (15W-40 for colder winters) works best and not only for cam break-in.
Another good one is Chevron Delo 400.
I heard even these will be reformulated starting in January. :confused:
On the road every day...
1952 Truck - 235
1948 Coupe - 261
#68176 11/04/2006 7:33 PM
The high mileage oils on the market have these additives. I found this out from the Mini forum I belong to. Seems that oil companies let us wear out our engines first, then give us the protection they need in their high mileage oils. I use Castrol 10W-30 or 40 depending on the temperature.
Jeff
#68177 11/06/2006 2:50 AM
Second that note from on the road again regarding Delo 400. I run it in my 261 with no oil filter, change it every 2000 miles and things look great.
cgresham1212
If you don't drive it, why have it?
55 1st Series 3100 5 window
#68178 11/06/2006 8:53 AM
I use either Delo 400 or Rotella T in my 261, too. It's really starting to get clean under the valve cover. I also use it in my BMW 325i.
Paint & Body Shop moderator
#68179 11/06/2006 7:43 PM
I was told by my old car machinest guy that delo 400 was the right stuff.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
