1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
So how was this thing attached to the frame? I've got some significant rust, and i want to be sure before i remove it.... i'm not sure if it was riveted;welded etc...
Do something! Even if it's wrong!
The one on my 52panel was bolted on. The bottom of it was rusted out so I ordered a new bottom for it from JimCarter.... but I'm sure available from some vendors in your area. An asembly manual will work wonders since your down to the frame. I highly recommend one and I believe they are only about $25.
You may already know about the online manuals but just in case your not here is a link....thanks to Keith Hardy.
http://chevy.oldcarmanualproject.com/
The battery holders on my 1954 trucks are riveted to the frame. And, the two threaded hold-down bolts are riveted to the sides of the battery box.
that makes sense. i'm gonna have to drill them out. the box is basically toast, but the threaded hold down's i can restore. thanks for the note about the assembly manual. i ordered one today. Just had to post this question.
Thanks guys!
