| | | Forums66 Topics128,108 Posts1,056,239 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 85 New Guy | | New Guy Joined: May 2010 Posts: 85 | So how was this thing attached to the frame? I've got some significant rust, and i want to be sure before i remove it.... i'm not sure if it was riveted;welded etc...
Do something! Even if it's wrong!
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | The one on my 52panel was bolted on. The bottom of it was rusted out so I ordered a new bottom for it from JimCarter.... but I'm sure available from some vendors in your area. An asembly manual will work wonders since your down to the frame. I highly recommend one and I believe they are only about $25. You may already know about the online manuals but just in case your not here is a link....thanks to Keith Hardy. http://chevy.oldcarmanualproject.com/ | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The battery holders on my 1954 trucks are riveted to the frame. And, the two threaded hold-down bolts are riveted to the sides of the battery box.
| | | | | Joined: May 2010 Posts: 85 New Guy | | New Guy Joined: May 2010 Posts: 85 | that makes sense. i'm gonna have to drill them out. the box is basically toast, but the threaded hold down's i can restore. thanks for the note about the assembly manual. i ordered one today. Just had to post this question.
Thanks guys!
