4 members (jmoore, DaveV, KEVINSKI, Youngin' Tut 59), 129 guests, and 3 robots.
Topics128,127
Posts1,056,681
Members48,452
Hello,
The engine on my '36 1.5 ton is missing the cap on the crankcase ventilator. I'm about to start hunting for one, and thoght I'd start here. Any suggestions where to find one?
Thanks.
Jeff, put the request in the swap meet under the Parts Wanted section. I'll bet a bolter out there has one.
I'm pretty sure I have one, I just need to hunt for it.
Send me a PM with your address.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks, I forgot about the swap!
Mike,
Thanks! I sent you the info.
Jeff
I think I have one too, if Mike B cant find his... let me know
Jeff,
I've never seen the Draft Tube mounted on the passenger side in a 1936 Chevy. Can you send me the casting numbers off of the block so I can confirm what you have?
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Ok, I'll check after lunch and let you know.
Jeff
Ok, my engine casting number is: 838941.
I looked it up and it is a 1939 engine...a 216.
I also found an ID tag on the firewall that was REALLY worn, but from what I could tell, it said:
Master 6
Car No. 21RD05 13785
Mike, hope the engine # can shed light on the placement of my vent tube. Any idea on the firewall tag #??
Thanks!!
Jeff,
Ok, you have a 216...makes sense now.
Your serial number 21RD05 13785 breaks down as follows;
21 = Janesville, WI assembly plant.
RD = 1936 Utility, 157" wheel base, 1-1/2 ton with Dual Wheels.
05 = May
13785 = Unit number starting at 1001.
The first RD from Janesville was built on October 8, 1935 and the last was serial number 21RD08 17221 built om August 21, 1936.
I found a vent pipe cap and will mail it out on Monday.
Take care.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Mike,
Wow! That's alot of good info on that ID breakdown! I guess at some point teh original '36 engine either was too far gone to do anything with, or someone upgraded?! So now I have a better idea of what I'm working with.
Thanks for the help, and for the vent cap too!
Jeff
