1 members (Hotrod Lincoln),
112
Mod | | | Forums66 Topics128,142 Posts1,056,491 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | I know it's in here somewhere but I can't seem to find it. What year model third member will replace the one in my truck? I believe someone said I could just change out the "chunk" instead of the whole affair. Thanks for any input. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | '55-'62. You will have to weld up the pivots where the axle housing bolts up to the springs.
Bill Burmeister | | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | Thanks so much. I'm not sure about the pivot joints but I'll try and locate them. Again, thank you, Steven | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | '55-'62. You will have to weld up the pivots where the axle housing bolts up to the springs. I just picked up 49 suburban can i do the same thing and any will a 55 chevy car 3rd member fit in the truck rear end houseing so i can run a regular driveline?? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | [/quote] I just picked up 49 suburban can i do the same thing and any will a 55 chevy car 3rd member fit in the truck rear end houseing so i can run a regular driveline?? [/quote Car won't fit but one from a truck will. ] They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | This is a picture of the pivot areas that need welded up on both sides of the rearend.Be sure to remove as much of the rubber grommets as possible,it will burn and drip out on you.Make sure you set the pivot angle of the rearend before welding. use 1955 to 1962 1/2 ton truck 3rd member. I used a 3rd member of a 1958 1/2 ton truck 3:90 gears in my 1951 suburban. Do a search on the subject,there is plenty to read. pivot areas Good luck, Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | One of the bolters actually had a series of photos on this topic at one point. Could still be there. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | What is gained by this swap?
If the truck will be used for in-town and highway driving would it be better to 'bite the bullet' and buy the gears from Patrick's?
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | I'm guessing the gain is the 'open' driveline and lower gearing.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | What is gained by this swap?
If the truck will be used for in-town and highway driving would it be better to 'bite the bullet' and buy the gears from Patrick's? Open driveline, slightly higher gears, depending on which 3rd member is used, flexability in transmission choices, such as overdrive.
Bill Burmeister | | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | I'm guessing the gain is the 'open' driveline and lower gearing. Read my by line below, 55K miles on a daily driver only vehicle with this set-up.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | Thanks for the info. By the way, you have a very nice looking 1951 1/2 ton. Really Nice. | | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | Hey Bowtietim, I have a question. What kind of rims are on your suburban? Long time ago, like when I was a teenager, I'm 60 now. My father let me date in his 1953 1/2 ton shortbed pickup. I put new seat covers on it and keep it clean. He used it to go to work in also. Granny 4-speed, heater. That's it. To make thi shorter I found some rims just about like that on your burb. They were supposed to be off a 1939 chevy. 6 lug. Just wondering if you might have heard of that. Thanks for lisening. Steven- Red 49 Truck | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Those are called artillery wheels. They were fairly common 50-75 years ago. Today they are quite rare. There is a repoped version available. Not sure what's on that burp, but they look darn good. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The original artillery wheels are hard to put modern tires on. The repops aren't real expensive as wheels go, and allow using modern tires. Check places like Chevs of the 40's for the repops.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | The original artillery wheels are hard to put modern tires on. The repops aren't real expensive as wheels go, and allow using modern tires. Check places like Chevs of the 40's for the repops. Why are they hard to put modern tires on??? | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Red 49 truck,The wheels are reproduction artillery wheels from wheel smith company.These wheels were actually cheaper than finding originals.This was the best route for me to go.
Thanks,Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | Red 49 truck,The wheels are reproduction artillery wheels from wheel smith company.These wheels were actually cheaper than finding originals.This was the best route for me to go.
Thanks,Tim Those look nice do you know if they will clear disk brakes? | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | bigtony55,I really don't know if they will work with disc brakes.My wheels are 15",you might call wheel smith and ask.
| | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | bigtony55,I really don't know if they will work with disc brakes.My wheels are 15",you might call wheel smith and ask.
Thanks,Tim These guys right? http://www.thewheelsmith.net/artillery_wheels.html
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | That's them,USA made !!!!!! 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: May 2005 Posts: 235 Shop Shark | | Shop Shark Joined: May 2005 Posts: 235 | cool thanks for the info! I'm lookin for wheel options. | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | This is a picture of the pivot areas that need welded up on both sides of the rearend.Be sure to remove as much of the rubber grommets as possible,it will burn and drip out on you.Make sure you set the pivot angle of the rearend before welding. use 1955 to 1962 1/2 ton truck 3rd member. I used a 3rd member of a 1958 1/2 ton truck 3:90 gears in my 1951 suburban. Do a search on the subject,there is plenty to read. pivot areas Good luck, Tim If i put the whole 59 rear end in my 49 suburban i wont need to weld up the pivot points since it was open driveline already will i? | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | That is correct. The pivot points are part of the original torque tube axle tube. Only need to weld them if you are swapping gears into an original axle.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Correct,but you will still need to make sure the pinion angle is correct.You may have to relocate the perches,I don't know if it's a direct bolt in.
Tim
| | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | I was at the local swap meet today and was about to buy a se of lowering blocks from a guy that wodl have been correct for my 49 rear end i told him i was swaping my 49 rear end with a 59 cameo rear edn he toldme the blocks wouldn't work because the 59 has round top u bolts isntead of square top u bolts and the leafs are 2" wide not 1.5" wide does that soudn correct ?? if so am i going to need to use the cameo leafs and shcakles etc in my suburban? | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Incorrect! You will be using your stock springs, but you will need new perches. Since the 49 is an axle over spring setup, the blocks will work to lower it. The Task Force trucks are axle under spring, so using blocks will actually lift the truck.
| | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | Incorrect! You will be using your stock springs, but you will need new perches. Since the 49 is an axle over spring setup, the blocks will work to lower it. The Task Force trucks are axle under spring, so using blocks will actually lift the truck. Si i need to get new pearches and move them on the bottom if i want to use 59 houseings?? can i just gut my 49 housing and put all the guts axles and all in it?? | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | IF you do need spring perches you can get them at just about any Mopar Dealer.
Mopar part # P4120074 last time I got them they were $10-15 for a pair....joe Mopar perches will work on a 59 chevrolet cameo rear end housing? | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | So if im going the run the 59 cameo rear end in my suburban can i use 55 suburban rear springs?? im not going to use my original springs they are to old and nasty LOL | | |
