The only information I have found with a Casting number 3788406 search is what I already know. 230 Chevy truck engine. I see that both use the same Conecting rods. Same part number.
So is the only differance between a 230 & 250 the Pistons & Crank shaft? 230 have a higher RPM due to a shorter stroke?
I realy would like to know if this 230 engine, plan on purchasing will work with my 250cid crank,pistons,cam good parts ect.
The 250 has a crack water jacket on the block. Thats why i need to replace it.
This is the number near the Distribitor on the 230 engine. F0215NE Have NO idea what the numbers mean?
