3 members (Gdads51, UtahYork, 1 invisible),
109
Mod | | | Forums66 Topics128,191 Posts1,057,364 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 25 | Hey guys, Has anyone used or have any info on the Welder Series Mustang II crossmember? It seems like a cost effective alternative to others like Heidt's and TCI. I do want to go with a Mustang II front suspension. I still need to sit down and add everything up to see if it will be cheaper in the long run to go with the Welder Series parts. Didn't the guys from "Trucks" tv show use one? I can't remember. Any comments welcome. TIA Dan | | | | | Joined: Feb 2004 Posts: 29,885 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,885 | Putting a suspension system designed for a subcompact car under a truck, even a pickup, seems to be a foolish decision, particularly if it's going to be used for anything other than a cruiser. Why not make a real truck system work, or at least go with a subframe like one for a Chevy Nova that's designed for a vehicle about the same weight as a stovebolt? Jerry
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Didn't the guys from "Trucks" tv show use one? They did. That episode is still available online. You should look at Scott Danforth's S-10/g-body based system as an alternative to the MII stuff.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jun 2009 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 25 | Hotrod Lincoln, I appreciate your input. But, after snooping around on here I have found that a few guys have Mustang II suspensions and have had no problems. My plan is to build a street cruiser. Nothing more. The added weight is a concern that I've had. But, once again, I haven't heard of any problems from guys that use them. OldSub, thanks for your input as well. I'll have to check Scott Danforth's system out. I just want a simple system that works. I like the Mustang II approach because I don't have to worry about any body mounts that are already on the truck. Don't have to remount the radiator ect... Any more input would be greatly appreciated.
DAN | | | | | Joined: May 2009 Posts: 41 New Guy | | New Guy Joined: May 2009 Posts: 41 | My Dad has a welder series crossmember in his 52. It works fine. That company is local to me and the owner used to own a hotrod shop. Paul Horton is a very nice man and builds quality parts. They have quite a pile of welder series products. | | | | | Joined: Oct 2008 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2008 Posts: 56 | I did a Nova subframe about 17 years ago. dumb, dumb, DUMB. Don't do it. Trucks with car frames are not fun.
I'd use the stock suspension and steering. Upgrade everything. That's what I'm doing on my 3/4 ton. It has a small block chevrolet mounted between the framerails hooked up to the original SM420 trans with a late 50's V8 bellhousing. Looks pretty stock. | | | | | Joined: Sep 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 46 | I have 2 scott danforth Suspensions one is in a half ton and one in a 3/4 ton.
My Half ton is set up with tubalar uper a arms a 4 link rear suspension with coil over shocks a narrowed 9 " ford with disc breaks the whole 9 yards
The 3/4 ton is set up the same on the front tubular upper a arms and that is where i ran out of money GO FIGURE huh
SO i may sell my 3/4 ton to fund my 1/2 ton.
The Scott danforth kit is VERY STRONGLY built actually over built compared to the M2 kits.
Jaime | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I have an OE Mustang 2 under my '40, including power steering. I haven't had any issues as far as durability or ride. From what I have seen, a lot of the aftermarket kits are heavier, and have available options such as coil overs, and tubular A Arms which would be nice upgrades. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I'm running an original stangII under my 37. Took it all out of a stangII myself at a salvage yard. I got it out of one that had the V8 engine as it had heavier springs. Although I did save some money I think if I did it again I'd go with one of the aftermarket set ups. There is just so much to be said for a kit that is precision cut and put together in some sort of permanent gig. It does take out a lot of work. But, like britcon, mine does drive and ride good with the rack and pinion power steering and its been under mine for 10 years without problems. The crossmember we manufactured was probably a little overkill as the entire truck doesn't weigh but just over 2600 lb. (I officially weighed it at a truckstop) .... but next time, if there is one, I think I'll go with the kit.
| | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | I have a 1973 Nova subframe under my 55 2nd series. Aside from the fact I have to have the frame lengthened, it seems to be ok. I won't know for sure until I build it. On a side note, a salvage yard here has a Corvette with the IRS still in it. I was thinking about buying it and using that under the rear. I may still go with a Nova rear axle. | | |
