0 members (),
361
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 34 New Guy | | New Guy Joined: Jul 2010 Posts: 34 | I'm looking for safe ways to lift my 1954 cab. I've seen someone build an elaborate frame/winch and one that uses an engine lift with a 2x4.
The engine lift seems to be an easier option. But instead of lifting it from the top of the cab, which looks scary, can you lift it from the cab to frame mounts instead? Or by strapping it around the bottom of the cab and lifting it from the center?
I don't want to modify a engine hoist to do this. Or should I just call 4 friends.
Thx! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | 4 friends would do, and you could supervise  not really too problematic any way you can rig up, the structure is pretty strong and if it's stripped bare it's not really as heavy as you'd think if working alone you might jack the cab up with 2x4's across the frame and jacks spread enough to roll the chassis out from under Bill | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | With the doors removed, two burly brutes can man-handle it. I did a moving strap through the doors and around the bottom and then lifted it with the engine hoist inside the cab. It was pretty unstable in the balance department but manageable. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I nailed a couple 2" x 4"'s together about 12" wide and 4' long looks like and "A" then insert that through the rear/front window so it catches the pinch weld area. I then reach my engine lift through the door. It does not touch the sheet metal only the wood and it is really pretty stable cost me about $5 bucks and I can move it without help. I looked to see if I had a picture but I could not find it. Then I made a little cab dolly to set it on and roll it around. http://community.webshots.com/photo/2727609370102454676uuRbEz | | | | | Joined: Jul 2010 Posts: 34 New Guy | | New Guy Joined: Jul 2010 Posts: 34 | So regarding the A frame; did the hoist push up on the frame, or pull. If it pushed, did your hoist just sit between the 12" wide space?
Thx for all the replies! | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | The engine hoist just comes in through the door against the wood of the A-frame. The open part of the A is going around the windshiedld divider the top of the A out the back window. So you only ever have wood to metal contact not metal to metal. This also does not touch the door frames where there is a chance of damaging the rain gutters which are a bear to fix. I am lifting the cab in the next week or so I will shoot some pictures and post them. | | | | | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | I've been told it's overly complicated, but I've moved a bunch of cabs around with it. It's not really a modification of the shop crane but an add on piece. CabLiftO'Matic Mongo | | | | | Joined: Apr 2008 Posts: 99 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 99 | | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | This is how I did it, worked really well. I have some scrap steel around and I'm going to fab up an assembly which works on a standard engine hoist. I'll post pictures when done.
Bruce | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Hi Brad. I like the idea of the wedge. I found the cab rocks a lot when up on the hoist. I didn't think of cutting a wedge.
Dennis -there is nothing stronger than the heart of a volunteer-
