3 members (MickeyP, Greg_H, GA Boy), 105 guests, and 3 robots.
Topics128,169
Posts1,057,035
Members48,458
Ok Guys an Gals got the my Truck home motor is stuck ...what would you do unstick to just to hear it ...or pull it an do the rebuild
http://s782.photobucket.com/albums/yy102/runtrunt2000/newbies%2052%206400/
time to settle an arguement did the 52' 6400 come with cab lights an turn signal....dad says no my brother syas they did I said they were an option loser buys all replacement lights
my bet: marker [3 center ones] and clearance lights [outside corners] could have been original in some jurisdictions, I don't think they were federally mandated yet in 52 but they were getting common by then - the turn signals would have been aftermarket, don't think GM made them until 54 or 55 - possibly "optional" at the dealer .... but I ain't buyin you any lights grin
The first thing you need to do is find out how bad it's stuck and why. Is the motor complete? are spark plugs in all the holes,carb there, etc? Has the hood been on to keep water out? If theres nothing obvious, you can put it in high gear and rock it a little to see if the motor turns. It may just be stuck enough that you can't turn it by hand. Of course some engines get bent rods because people pull them while in gear to break them loose. You can pull the plugs and squirt something in the holes, every one has their favorite miracle substance. Rocking it with the plugs out will also tell you a little more. If it gets to where it turns over, you should be able to start it.
'65 C-10, 65 L-60, 65 C-80, 72 C-60 & and a bunch of old Chevy cars.
Never time to do it right, always time to do it over.
Apprentice
Apprentice
yes to cab lights (light, singular would be appropriate)and the turn signal mounted on top of the fender. Two marker lights in the grill. Not sure if turn signals were after market but all the same year trucks I've seen either has them or witness marks and wiring to show that they were there at one time.
remove valve cover and soak valve train with your perfered mixture let soak for a few days and tap valves with hammer, that way you won't bend push rods if any valves are stuck as well when you turn motor. would fill cylinders and let them sit for several days. beware of standing in front of open spark holes if you get it turning may squirt leftover fluid all over your clothes.
My dad bought a '47 where the motor would not turn over. He thought about rebuilding the motor but decided to just pull it apart to see what was going on. What he found was a single kernal of corn that had dried up and fell in thru an open valve when a mouse was living in the exhaust. That one piece of corn was keeping the piston from following thru the entire stroke and stopped it just before TDC.
He put the motor back together, and drove it for 2 years. Moral of the story? Open it up, see what is wrong before the most expensive route is decided. If you are doing a full restore, it would be worth pulling the motor to rebuild. If, like me, it's going to be a work truck, try to get it running first.
Just my opinion.
Good luck,
Dave
Pull all the plugs out and squirt each cylinder full of something like Marvel Mystery oil. Let it set a couple of weeks and then try turning it over with a pry bar on the starter ring gear. Its worth a try.
truck is complete sat for about 10 yrs everything is original I pulled the plugs an filled cylinders with Marvels an its been about 2 weeks so I'm gonna try an turn it and if it breaks free I'm gonna try an start it up...might drive around barn lot just for kicks then tear it down
I would attempt to get it freed up and get it running. I have heard of people freeing up stuck engines and driving them for years without problems or excessive oil usage. If you can get it running why not....if you have to tear it down so be it, but you may avoid it for a bit.
Make sure you pull off valve cover and tap valves to make sure they are not stuck though first.
1946 Chevy OS 1.5ton, 1955 GMC 3100, along with other various IH,Ford,Nash,MGB,.....
Signal lights were very common but not factory options on Chevrolet/GMC trucks until 1954. Single-faced and double-faced signal lamps were available as Chevrolet truck accessories prior to 1954; however, I do not know if they were available for all earlier Advance-Design years.
1st attempt to turn motor failed pull valve cover all valves are free filled cylinders again gonna let set and try again next week
Get some Kroil, and pour 2 or 3 ounces in each cylinder.
www.kanolabs.com
Best penetrating oil I've ever used!
Kroil
