5 members (66flea, cmayna, Wally / Montana, walter74, Forty9), 110 guests, and 2 robots.
Topics128,154
Posts1,056,838
Members48,456
I posted to the welcome forum last week about my 1948 1.5 ton that I got in April. You can see pictures of her there if you are interested. She is in pretty good shape and rust is not a problem on her.
My truck has a hydrovac booster and I've search the site for answers about bleeding and filling but haven't found anything helpful. It is suggested to fill the power cylinder with air tool oil and fill the hydraulic part with brake fluid...looking at the drawings it is not clear to me where these places are located. I'm guessing the power cylinder is filled at the little square plug about 3/4" of and inch from the bottom of the unit...where do you add the brake fluid? Do you just fill it from the master cylinder under the cab floor and force it thru the hydrovac or is there a place on the hydrovac to add brake fluid? I know it sounds stupid but I don't want to add the wrong in the wrong...u know? Thanks for any help.
Motoswiz
1948 Chevrolet 1.5-Ton Dually
More pix on Photobucket
Motoswiz
North Florida
there's a good hydrovac build tip here, should learn ya all about'em
Thanks Bill, yeah, I read all that and it still doesn't address adding brake fluid to the hydrovac unit itself...I guess I just pump it from the main under cab cylinder. there is a plug on the top of the unit but the drawing and part description don't address it becasue it is on the other side of the drawing.
Motoswiz
North Florida
Use a pressure bleeder at the master cylinder. Your hydrovac probably looks something like this. http://picasaweb.google.com/crenwel...V-EjYHMFbfQmBCHVMQYg#5513221911802295266 There are 2 bleeders. Bleed No. 1 first, then No. 2 and then the wheel cylinders.
Very similar to the one in that picture, crenwelge, but mine is longer in the main cylinder section. ...thanks for posting it. I'm charging my camera batteries so I can post a couple pix of the plugs.
Motoswiz
North Florida
Simply put, yes. You won't need more than an ounce or two of fluid in actually lubricating the power cylinder.
The internal parts are lubricated as the brake fluid passes through the hydraulic cylinder. There aren't any other places to add fluid.
Jeff
My 1953 Chevrolet
1947.1 Gallery
Apprentice
Apprentice
http://chevy.oldcarmanualproject.com/
There is a section dedicated to just the hydrovac booster. I'm sure that it will tell you how to service the unit.
