| | | Forums66 Topics128,048 Posts1,055,541 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 217 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 217 | I have a Campbell Hausfield MIG welder, it has been working very well for me with Flux Core but, today I thought if it works this well with Flux Core imagine how well it would work with gas. Man, was I disappointed. I went to the local welding supply and they set me up with some C25 and .030 wire. I set the welder up as directed in the manual and began welding. I tried every adjustment on the machine with no luck. It was EXTREMELY disappointing. I switched back to Flux Core and wonder why I even wasted the time or the money.
The main issues I had was poor penetration and weld beading up. It would often leave a big bead on the end of my wire. There was no bacon sizzle noise and often sounded like arcing.
Does anyone have any suggestions? | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | As part of the setup you switch the leads for the gun and ground. I recently forgot to do that and ended up with exactly what describe.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Nov 2001 Posts: 217 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 217 | I did everything like the manual said. I'm just baffled. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You may not be getting gas to the tip. Don't give up. When you get it right you'll love it. | | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | In my Hobart 140 Mig, I have to change the polarity. Once you get using gas you wont go back to fluxcore and you may have done that but just in case you cannot fluxcore wire and gas togeather. You need to use regular steel wire. Play with gas pressure
Ganesh | | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | Also, you might want to use .025 wire.
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. -Unknown-
| | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | And I assume you were holding the tip within an inch of your work??
| | | | | Joined: Nov 2001 Posts: 217 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 217 | Well, I'll try it again, I think I was doing all things suggested. I'll try the .025 wire as well. I'll let you know the results.
| | | | | Joined: Nov 2001 Posts: 217 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 217 | Well, I think the problem was 2 things. First, I think I was losing power through an extension cord. Secondly, I think I needed to play with the settings a little. I've got it working now! Thanks for everyone's suggestions. | | | | | Joined: Aug 2010 Posts: 32 Apprentice | | Apprentice Joined: Aug 2010 Posts: 32 | You should know it shouldn't sound like bacon..with popping and sizzle....just a constant arc. If you hear that sound something isn't right. | | | | | Joined: Oct 2010 Posts: 21 New Guy | | New Guy Joined: Oct 2010 Posts: 21 | My welder sounds like bacon. I love my Miller 200, but still like to burn rod with my Lincoln buzzbox. Just take your time and work with it.
1940 Chevy 1 1/2 ton, 1959 Chevy 1/2 ton, 1966 Chevy C20.
I can explain it to you but I can't help you understand it.
