3 members (5 Window 9434, MRMEROTH11, 1 invisible), 75 guests, and 2 robots.
Topics128,066
Posts1,055,874
Members48,428
#656914 06/24/2010 1:47 AM
1 Offline
I have a Campbell Hausfield MIG welder, it has been working very well for me with Flux Core but, today I thought if it works this well with Flux Core imagine how well it would work with gas. Man, was I disappointed. I went to the local welding supply and they set me up with some C25 and .030 wire. I set the welder up as directed in the manual and began welding. I tried every adjustment on the machine with no luck. It was EXTREMELY disappointing. I switched back to Flux Core and wonder why I even wasted the time or the money.
The main issues I had was poor penetration and weld beading up. It would often leave a big bead on the end of my wire. There was no bacon sizzle noise and often sounded like arcing.
Does anyone have any suggestions?
1954 Chevy 3100
1952 Chevy Suburban
As part of the setup you switch the leads for the gun and ground. I recently forgot to do that and ended up with exactly what describe.
Larry
I don't own a vehicle that isn't old enough to drink.
1 Offline
I did everything like the manual said. I'm just baffled.
1954 Chevy 3100
1952 Chevy Suburban
You may not be getting gas to the tip. Don't give up. When you get it right you'll love it.
In my Hobart 140 Mig, I have to change the polarity. Once you get using gas you wont go back to fluxcore and you may have done that but just in case you cannot fluxcore wire and gas togeather. You need to use regular steel wire. Play with gas pressure
Ganesh
Also, you might want to use .025 wire.
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
-Unknown-
And I assume you were holding the tip within an inch of your work??
-Unknown-
1 Offline
Well, I'll try it again, I think I was doing all things suggested. I'll try the .025 wire as well. I'll let you know the results.
1954 Chevy 3100
1952 Chevy Suburban
1 Offline
Well, I think the problem was 2 things. First, I think I was losing power through an extension cord. Secondly, I think I needed to play with the settings a little. I've got it working now! Thanks for everyone's suggestions.
1954 Chevy 3100
1952 Chevy Suburban
Apprentice
Apprentice
You should know it shouldn't sound like bacon..with popping and sizzle....just a constant arc. If you hear that sound something isn't right.
My welder sounds like bacon. I love my Miller 200, but still like to burn rod with my Lincoln buzzbox. Just take your time and work with it.
1940 Chevy 1 1/2 ton, 1959 Chevy 1/2 ton, 1966 Chevy C20.
I can explain it to you but I can't help you understand it.
Moderated by  MNSmith
