12 members (Charles in CA, MickeyP, GIJOE298, joe apple, Jon G, Ribside, 3B, Bill Hanlon, lumbersawyer, 55shaker, dt235sd, 1 invisible),
97
Mod | | | Forums66 Topics128,134 Posts1,056,738 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 20 Apprentice | | Apprentice Joined: Oct 2008 Posts: 20 | Just got my truck back together after a ground up restoration. Took it for it's first ride and seem to have a lot of play in the front end. Installed 3 1/2 inch drop axel removed 2 springs out of eight had wheels balanced and an alignment. When i hit a bump the front end wonders all over tried to adjust the steering box and made no difference. Can someone tell me the proper way to adjust and if it is common for steering boxes to have major wear. | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | do you get the "wander" condition only when hitting a bump ? could be "bump steer". i see you have a dropped front axle. your drag link needs to be parallel to the frame.
i have a 3 inch dropped axle and 1 leaf removed in my 57, with original steering box and leaf spring bushings, and it runs perfect at 80mph.
a few other guys will chime in here before too long also.
leonard | | | | | Joined: Oct 2008 Posts: 20 Apprentice | | Apprentice Joined: Oct 2008 Posts: 20 | seems to wonder all the time but when i hit a bump its worse | | | | | Joined: Oct 2008 Posts: 20 Apprentice | | Apprentice Joined: Oct 2008 Posts: 20 | I have also done all new springs pins and bushings the only thing i did not do was tie rods and drag link all seemed well. | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | And it was fine before, right? Sounds like a geometry problem. Look at the drag link like Leonard said, if its not parallel or darn close, that will produce bump steer.
Also, maybe the king pins are too loose? | | | | | Joined: Oct 2008 Posts: 20 Apprentice | | Apprentice Joined: Oct 2008 Posts: 20 | One king pin seems a little loose I have ordered .10 over will be trying that first.
| | | | | Joined: Oct 2008 Posts: 20 Apprentice | | Apprentice Joined: Oct 2008 Posts: 20 | Just added new pictures in photobucket check them out. Thanks for the info will let you know about drag link. | | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | Think I'd check the toe in first.
58 gmc 100 with 350 sbc
| | | | | Joined: Oct 2008 Posts: 20 Apprentice | | Apprentice Joined: Oct 2008 Posts: 20 | the drag link has a slight upward taper to the front. Alignment was done both wheels .03 out all good there. | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | yes, you want the drag link parallel or it will drive you nuts. small suspension travel will make it wonder a little, and large suspension travel will want to pull the steering wheel out of your hand. by the way, great looking truck. i like it.
leonard | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | That's quite a transformation. Great looking truck!
Spot
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | |
