5 members (TUTS 59, Otto Skorzeny, 52Carl, Gray_Ghost, ShopRag), 122 guests, and 2 robots.
Topics128,130
Posts1,056,714
Members48,454
#676742 09/08/2010 11:38 PM
Apprentice
Apprentice
Just got my truck back together after a ground up restoration. Took it for it's first ride and seem to have a lot of play in the front end. Installed 3 1/2 inch drop axel removed 2 springs out of eight had wheels balanced and an alignment. When i hit a bump the front end wonders all over tried to adjust the steering box and made no difference. Can someone tell me the proper way to adjust and if it is common for steering boxes to have major wear.
do you get the "wander" condition only when hitting a bump ?
could be "bump steer".
i see you have a dropped front axle.
your drag link needs to be parallel to the frame.
i have a 3 inch dropped axle and 1 leaf removed in my 57, with original steering box and leaf spring bushings, and it runs perfect at 80mph.
a few other guys will chime in here before too long also.
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
Apprentice
Apprentice
seems to wonder all the time but when i hit a bump its worse
Apprentice
Apprentice
I have also done all new springs pins and bushings the only thing i did not do was tie rods and drag link all seemed well.
And it was fine before, right? Sounds like a geometry problem. Look at the drag link like Leonard said, if its not parallel or darn close, that will produce bump steer.
Also, maybe the king pins are too loose?
Apprentice
Apprentice
One king pin seems a little loose I have ordered .10 over will be trying that first.
Apprentice
Apprentice
Just added new pictures in photobucket check them out. Thanks for the info will let you know about drag link.
Think I'd check the toe in first.
58 gmc 100 with 350 sbc
Apprentice
Apprentice
the drag link has a slight upward taper to the front. Alignment was done both wheels .03 out all good there.
yes, you want the drag link parallel or it will drive you nuts. small suspension travel will make it wonder a little, and large suspension travel will want to pull the steering wheel out of your hand.
by the way, great looking truck. i like it.
leonard
That's quite a transformation. Great looking truck!
Spot
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
