| | | Forums66 Topics128,026 Posts1,055,403 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 132 | Anyone have an idea on how to free up a stuck cable? thanks Brett | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | WD-40 or other penetrating oil sprayed into both ends?
Soak the entire cable assembly in a solvent?
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | | | | | | Joined: May 2010 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 144 | Brett, I use Kroil penetrating oil to loosen anything. try to get it in both ends of the cable if possible. It is amazing stuff. It will creep and break the molecular bond that has "fused" the two parts together. The gunsmiths turned me on to it. They use it to free rusted screws in antique guns. See http://www.kanolabs.com/google/ John | | | | | Joined: Apr 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 132 | Thanks for the help, I did'nt think oil would work. I love Kroil, I've been using it on all my stuck parts. Thanks again Brett. I'll try to get more pics of my new power disc brakes. | | | | | Joined: Feb 2000 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2000 Posts: 38 | | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | +2 for kroil. If you have it out of the vehicle then "slap" it on the ground a few times after you soak it. That'll break it up! | | |
