4 members (Otto Skorzeny, 2-Ton, MNSmith, 1 invisible), 142 guests, and 3 robots.
Topics128,088
Posts1,056,114
Members48,434
#675696 09/05/2010 12:28 PM
hello, does anyone have any advice on how to get heat to the auto choke when using fenton headers?
From what little I know about Rochester carburetors, I suppose you are referring to a Rochester model "BC" carburetor that uses a metal tube that transmits heat from a sheet metal "stove" that would be clamped to one of the exhaust manifolds?
A low-buck way is to wrap Small copper tubing around the exhaust manifold and hook the choke to that. It works OK, just looks a little funny. Run the other end back to the air cleaner for clean filtered air.
Joe
Joe H #675723 09/05/2010 3:49 PM
The Fenton's have a brass plug in them that can be removed. There are kits from several suppliers listed on this site that run tubing off those threaded holes to the manifold box. They transfer the exhaust manifold heat to the chamber. It works very well for me, but I'm in Miami. Might not work so well in, say, North Dakota.
