5 members (Hotrod Lincoln, tesa, Nick in Manitou, J Lucas, klhansen), 220 guests, and 2 robots.
Topics128,088
Posts1,056,002
Members48,430
Trying to decipher exactly what engine my truck came with, I know (think?) it's from something in the mid seventies. Anyone good at interpreting the casting numbers? See photos and let me know what I've got. It's an L6.
Thanks.
http://s843.photobucket.com/albums/zz356/blatham489/Chevy%20L6%20Block%20Casting%20Nos/
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
It looks like a 250.
Steve
'49 3800
'52 3600
'57 3100
Hoping for a link to a decoder to verify size, date, etc.
The 348675 casting is one of many used for 250 engines w/o the integral intake according to the Chevy Inline Six Power Manual.
I don't know of a link, sorry.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
If you can find the engine serial number on a raised area near the distributor,ex. "F0118JA" you can go to this site, http://no25.chuckthetruck.com/index.html (use page 3} and look for the last letters in the engine serial number, ex "JA" and see the year and application it was built for. Or if you just list that serial number here someone can probably help.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
I had seen that page, and have now found the engine SN. But mine is like the one you listed - F0###00T (or maybe F0###CCT). But the "F-" only shows for 66-67 Olds F-85, doesn't seem right based on being told that it was from a mid-late 70's with an HEI ignition.
Basic misunderstanding happening here. The first letter in the engine serial number indicates the production plant. So "F" stands for "Flint". The next two numbers are usually the month of production, the next 2 numbers the day of the month and finally the last one, two, or three letters indicate the engine application.
The list at the chuckthetruck site is only using the engine app
letters at the end of the serial numbers, so try to accurately determine your letters at the end of your serial number and search the 70' years at that site.
Originally Posted by The Green Farmer
(or maybe F0###CCT)
That says 250 out of a 71 truck with a turbo 350 behind it.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Thanks, that helps a lot. However, I still don't find CCT (last 3 digits), but at least it fits the format and at the top of the page it says it is not a complete listing. Seems pretty clearly a 250, and casting no's would indicate a late 76 model vehicle. Any further information would purely academic at this point, so unless someone likes playing detective, I've got what I need.
ETA - Somehow the post above wasn't there when I posted. - Thanks Fried - mystery solved.
1953 3/4-Ton Chevy
More pix
If it can be built ... It can be fixed.
RB53
Need help with my engine serial numbers also guys,FI226H,any idea's ?was told it was mid 50's 235
F1226H
I think these decode as (someone will correct me - I could be way off):
F = Flint MI
12 = December
26 = 26th
H = engine size and application (maybe someone knows)
Here are locations for codes on many high-pressure 235/261 engines
The head and block date casting codes will help in the IDing.
The "H" decodes as a 62'-63' 194 passenger app at the chuckthetruck site I previously mentioned. It also decodes as a 57' 235 at this site, http://www.chevytrucks.org/mikesgarage/1957.htm
You need to compare your block casting no. with the list at the Inliners site given previously in this topic to further confirm your engine size and app.
