7 members (1955 1 Series, Wayne67vert, Brian Moore, Jon G, KEVINSKI, 50Chevy3100, 1 invisible), 50 guests, and 10 robots.
Topics128,012
Posts1,055,311
Members48,419
#673496 08/27/2010 7:26 PM
This is the anal question of the month...I have a '48 Chevy 1/2 ton p.u. I see the tailgate chains hooked on in either direction. Is one more proper than the other, or does it come down to personal preference?
fonz8261 #673541 08/28/2010 12:07 AM
Phew! "anal question"! You had me worried! I've heard of pierced nipples and nipple chains, but you just gave me a whole new visual for 'tailgate chains'. Seriously though, I seem to recall that the old adds showed the chains run from the outside in. I always thought it looked backwards the other way.
twotone #673547 08/28/2010 12:17 AM
The chains lay better when in the right way. On '54 and up they go in from the bottom.
Cletis #673551 08/28/2010 12:33 AM
I solved that problem when I bought my new bed from Mar-K. One of their options for a few bucks more (it's only money) is a hidden tailgate latch.
http://www.mar-k.com/what_s_new_at_mar-k.html
That is the only non-original look other than the 5" suspension drop I have made on the truck; after all it's only original once.
~Jim
twotone #673595 08/28/2010 4:36 AM
I thought it went: Sticks and Stones may break my bones But Whips and Chains Excite Me! headscratch
GMC: Get More Cash...
1958 GMC
My Webshots photos
1958GMCnut #673629 08/28/2010 12:41 PM
WOW--I guess that created some excitement! Thanks for the entertainment and the friendly advice.
Cletis #673630 08/28/2010 12:45 PM
I'll be damned. Never knew that...
I'am under the inpression. The easyest way of insertion with out intanglement,is the proper mounting arrangement.
theres a tool for every job,and that tool is a hammer. it's easy to give advice if it's not your pocket book at stake. A well thought out plan,Is nothing. Untill exacuted twice.
49 floyd #674062 08/30/2010 3:36 AM
As, I said, the '54 and up chains lay right when inserted right. The bend of the hook makes them lay right. If you have repro hooks they may need to be bent to match original ones. Mine did.
Cletis #674122 08/30/2010 2:18 PM
Cletis, You seem to have these chains figured out.
Do you have a tutorial on how to bend them or some good pictures and measurements for making them so they work right?
Mine came with 60d nails for hooks. I got them so they work but they don't lay right and have been rubbing the paint.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Sorry, I didn't take pics. I had a rusty pair of originals to work from.
Cletis #674354 08/31/2010 11:02 AM
Cletis isn't it an S-bend with a 90 degree twist? I'm not near my truck now or I'd go out and have a look. The 90 deg twist allows it to lie flat against the bed at the chain end, while hanging clear through the hole up top.
I got the rubber chain tube protectors that keep it from swinging against the gate frame and fenders, but I thought they were way too short to be fully effective. I added some bicycle tire innertube to bridge the gap between the rubber chain tube protector and the hook. Little damage now. (Sure wish the chinese would cut those things about 4" longer and allow US to trim them to fit! Cheapskates. grrrrr)
TxLaTx #674416 08/31/2010 3:43 PM
That's because we use US inches and they use metric. eeeek
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
PapaJ #674922 09/02/2010 6:39 AM
Quite the question. I thought someone was going to ask what color of air was in the tire originally!! As to tail gate chains. Be different. Put one through from the outside and the other from the inside.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
