7 members (51sub, WICruiser, greenie-reddy, NJC, Peggy M, Tronman, Gray_Ghost), 102 guests, and 2 robots.
Topics128,265
Posts1,058,360
Members48,485
#674733 09/01/2010 6:31 PM
I have a question about my rear leaf springs on my 46 half ton.I am planing on taking them apart ,blasting them and then using poly liners between the leafs like I did on the front.But I noticed there are 10 leafs in the spring pack,from everything I have read there should only be 7 or 8 leafs.They are the 1 - 3/4 wide like they should be but why would I have 10 leafs?
Thanks for your help
Longhorn
Longhorn #674773 09/01/2010 9:02 PM
Riding in the Passing Lane
Often leaves were added to the truck to carry more weight. You can often tell which ones have been added. They usually are square on the ends & while the original have a bevel. Sometimes the length doesn't seem right.
1972 Chevy c10 Cheyenne Super
When I was in high school I had a '54, 1/2 ton. The truck was lower in the front on the driver's side. My friend who had been an auto mechanic since 1919 told me that was from wear & tear and the truck almost always being driven without a passenger...maybe. Anyway he told me I could take the almost flat spring off, take it apart, try to re-arc the leaves in my vice and add an extra leaf...one of the smaller ones. I did all that and it worked.
Jacques
Union, Justice and Confidence
swampcat #674812 09/01/2010 11:19 PM
I think I have your truck Jacques! Mine sits exactly like that right now.
lightflyer1 #674825 09/01/2010 11:48 PM
lightflyer1, my truck never looked as good as your's! Mine was a rust bucket but mechanically great. I wish I had still had it.
