0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 201 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 201 | Anyone have a torque/HP curve for a stock 250? Trying to pick a rear end gear and a torque curve would be helpful.
Thanks in advance.
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
| | | | | Joined: Feb 2000 Posts: 5,208 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,208 | No dyno chart, but according to calculators, mine is making about 150hp at the flywheel and 125 or so at the ground using dragstrip time sheets. This just what a stock engine should make.
I am using a 3.08 rear axle with a T350 trans and stock 250 engine. My truck weighs 3350 with me in it. I changed from a 3.42 due to highway rpm. I losts some low speed torque, but I gained out on the road. I drive 65 to 70 most of the time so it was a good trade. Rear tires are 235/75 R15 radials.
Joe | | | | | Joined: Oct 2009 Posts: 201 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 201 | Thanks for the input. Mine's got what appears to be a 2.40 rear end, seems a little highly geared. Like you I'm also running a TH350. I'll actually be on side streets more often than not so I was even thinking something lower, like a 2.73 or along the lines of the 3.08 like you've got. So you're running around 2600 at highway speeds? Not too buzzy? A 2.73 would put me around 2300.
ETA - PS Like your truck. Pretty much what I'm going for - period correct looking, but with modern driving comfort.
| | | | | Joined: Nov 2005 Posts: 266 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 266 | Farmer, the Restoration Pack that I ordered from GM has the stock dyno charts for a '66 250 in it. If I remember when I'm home from school this weekend, I'll scan it and upload it to webshots. If you want, I can send you an email with it as well. | | | | | Joined: Feb 2000 Posts: 5,208 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,208 | 2600 is about right at 65 mph. Its just the right rpm, has plenty more for passing and enough torque to hold steady speed.
I wouldn't go any lower then a 3.08, I can't imagine how doggy that 2.41 is. Mine is bad enough with a 3.08 compared to the 3.42!!!
Joe | | |
