2 members (joe apple, klhansen), 137 guests, and 1 robot.
Topics128,157
Posts1,056,874
Members48,456
Page 17 of 177 1 2 … 15 16 17 18 19 … 176 177
I used American Autowire on mine. With 22 circuits it was a lengthy process. My suggestion would be to take your time and do a little each day.
~Jim
Installed the park lamps. Next up, figuring out how to wire in the flasher for the turn signals.
Nothing;
Was working on my "other" truck trying to get the seat springs back on and slipped, gashing two fingers, that sent me to the emergency room thinking that I might need stiches, got it cleaned out and band-aded up, got home and haven't done anything yet until I heal.
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
Big Chev. You are scaring me. Want a vacation in Michigan to help?
Too hot to leave the house. Anyway you would do better alone; too many cooks spoil the broth. Check with Mad Electric for wire connectors. Their butt connectors are great for soldering joints and shrink tubing. Also they have the greatest crimping pliers I have ever used. Get a wire stripper from Home Depot; that will save you a ton of time.
http://www.madelectrical.com/catalog/butt-connectors.shtml
~Jim
That is good advise BIG CHEVY. Solder all connections.
Turn signals and horn installed and working!! Woohoo!!
I went out and looked at it, does that count,
Drive with Pride. mike j
family pic
Y
Y Offline
Painted the hood and cowl panel on my burb today.
Installed the right running board after sanding, welding, priming, painting and replacing two of the brackets. Also installed a new running board to cab seal. I find it amazing how something which I thought would be simple took so much time! (but it looks good)The left side is next but it's in better shape (i.e.wasn't bashed by any stumps!)
It's a small world, but I wouldn't want to paint it.
Didn't DO anything on it, but we took it for a ride. Two of the grandkids were here, and they love to take a ride in the big blue truck! So that's what we just got back from doing.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
I installed the torque converter lockup kit for the 700r4 trans. I put in the '66. Now I have overdrive!!!
Ted.
Installed running board to cab seals, door handle seals, wiper arm seals, inside window surrounds, defrost deflector, "3600" badges on the hood, mounted license plate and taillights on a temporary 2x4 since I have no bed (yet).
I'm at the fun part where everything is clean and painted and just needs to be re-assambled. Things are going quickly and it's getting to be more fun. Plus we can drive it around. Took the boy for a ride (he's 2), he loves it.
Treated the engine to some new parts, plug wires,chrome PCV,throttle spring,thermostat,hoses.
Got my radiator and new fan mounted,and finally got the rear end lubed up,it's been dry for the last 4 years!
More pix on Flickr.
Mounted new (to me) original 8-lug split rims, tires and caps that I purchased from a fellow Stovebolter. NOW it's starting to look like a real truck!
Finished up the installation of new bed rails.
New Bed Rails
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
New Bed Rails
Beautiful!
Got the steering column painted and the bed-wood sanded.
~Jim
Nothing, since it is running good I have been using it for daily driver and it has been trouble free for about 2 years now.
well with any luck got the last of the patch panels in this morning before the heat of the day, supose to be 100 + so started a 6 and finished up around 11, not to bad 3 panels in ground down and a little metal to metal added for good measure, who said these old trucks can't be fun
family pic
Darn brake power booster/parts didn't arrive yet, so I just suffered through this weekend, by taking it for a cruise. grin
They say it was shipped Friday, so next week it's power disc brakes for Sunny. cool If things go as planned, yaa right. wink
For some reason most of my parts are shipped on Friday. Bummer...
~Jim
Drove Grandpa for the first time in 8 months. New brakes, wheel cylinders, wheel seals and cleaned-up rims sporting new rubber.
Looky here
The full album can be found here
It was a good weekend
Brian
Slinger, WI
'37 3/4 ton (grandpa)
'11 3/4 ton (grandson)
http://picasaweb.google.com/lh/photo/4xMv20nIhYF_AUPgEkRiFQ?feat=directlink
I have been converting my Suburban from SM420 to an SM318 with B/W OD. Of course I had to swap out the torque tube rear. It has been fighting me every step of the way.
But I'm finally seeing the light. I have a re-built 3.90 rear installed in a '55 1st housing and the tranny installed with shifter hooked up.
Last night I made up a harness for it and got it installed. I got one u-joint installed but the other was too big. Back to NAPA to exchange it today.
I still need to install the lockout cable.
But after 2 months of cleaning parts, overcoming set-backs and obstacles and cleaning more parts I should be back on the road this week. WOOHOO!
Adjusted the drum brakes and filled the master cylinder resevoir (where did all the fluid go?). Kind of a mystery as there are no leaks anywhere. Maybe the guy I bought it from never got it full. Pedal is high and hard, now, and I can skid to a stop smile
Also, tightened up the steering box. The whole frontend had been rebuilt and aligned but we were still wandering all over the road. The free-play (sector shaft) adjustment was way too loose. Much better now and I feel safe all the way up to 55 mph, which I didn't before. I think I'm going to drive it to work, soon.
Y
Y Offline
Sanded all the paint off the grille for my 51 Burb, and got it primered before the sun went down. Now what to do, I wore my fingers down to the nubs? Maybe a cold beer will help keep the swelling down!
Perhaps one beer for each finger and two for each thumb. That should do the job...
~Jim
Apprentice
Apprentice
Today I installed a new carburetor insulator with the hope that it will solve a problem. My 48 216 1/2 ton is hard to start when the engine is hot. It starts when cold, but after it has run down the street and back it must cool off before it will start.
I had to use the old carburetor gasket because Truck Stop sent me the wrong insulator gasket. See ya going for a test drive
Today, I got the cab interior repainted. It was the conclusion to an entire summer's worth of work of disassembly, stripping, grinding and sanding, in 90 to 100 degree weather. YEAH!!!(that is me dancing in the street). Now the fun part starts.
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
-Unknown-
Where are those pics di, we need proof. pix
~Jim
Put the pilot bearing, clutch, pressure plate, fork, fork ball, and throw out bearing back in the ol 38. Waiting on tranny bearings and gaskets. Would like to have everything back together by Labor Day - have to wait and see.
Here they are Big Chevy.
Interior pictures
-Unknown-
Now that looks GOOD!
~Jim
Looks like a new one, di1953gmc.
I finished up the OD install last night. I just got back from the test drive. Still need to do some adjustment on the shifter but everything else worked as it's supposed to.
WOO HOO! I'm pumped. Kansas City here we come.
Installed a rebuilt steering gear box on my 58 fleetside. I'm beat. Putting the steering wheel back on tomorrow and I'll be finished.
1958 Apache Shortbed Fleetside
Reinstalled the exhaust and turbocharger after powdercoating.
prepping to fit the cab in a couple weekends.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
I changed engine oil and filter, greased chassis and driveline, adjusted valves. I then loaded Dad's cement mixer to haul back to him after I borrowed it this spring to pour sidewalks around my new shop.
Remember 9-11-01--God Bless the USA
JUSTICE, not REVENGE, will prevail
1951 Chevy 1/2-ton Pickup truck
Tomorrow (Sunday) i'll get some time on the truck.
I'm just waiting on my new driveshaft,but will lay out my trans cooler lines,fit and secure the brake booster vacuum hose.
That's what I'd like to do, but in reality......... ohwell
More pix on Flickr.
Finished putting the steering wheel on after the steering box swap. Since I had to remove the exhaust pipe going into the left header in order to renmove and install the box, I have an exhaust leak at the header due to a bad seal. Will tighten everything back up tomorrow. Also installed a new turn signal switch, due to a bad one.
Took the Apache for a test drive and what was 3 feet of steering wheel play has been knocked down to just a hair of play.
well put the green to it today can sure tell where i missed getting some body work done, looked good put could have been better, she's a driver
family pic
