1 members (NJC),
93
0
Mod | | | Forums66 Topics128,260 Posts1,058,343 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 812 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 812 | This is the anal question of the month...I have a '48 Chevy 1/2 ton p.u. I see the tailgate chains hooked on in either direction. Is one more proper than the other, or does it come down to personal preference? | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | Phew! "anal question"! You had me worried! I've heard of pierced nipples and nipple chains, but you just gave me a whole new visual for 'tailgate chains'. Seriously though, I seem to recall that the old adds showed the chains run from the outside in. I always thought it looked backwards the other way.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The chains lay better when in the right way. On '54 and up they go in from the bottom. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I solved that problem when I bought my new bed from Mar-K. One of their options for a few bucks more (it's only money) is a hidden tailgate latch. http://www.mar-k.com/what_s_new_at_mar-k.htmlThat is the only non-original look other than the 5" suspension drop I have made on the truck; after all it's only original once.
~Jim
| | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | Phew! "anal question"! You had me worried! I've heard of pierced nipples and nipple chains, but you just gave me a whole new visual for 'tailgate chains'. Seriously though, I seem to recall that the old adds showed the chains run from the outside in. I always thought it looked backwards the other way. I thought it went: Sticks and Stones may break my bones But Whips and Chains Excite Me!  | | | | | Joined: Jun 2009 Posts: 812 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 812 | WOW--I guess that created some excitement! Thanks for the entertainment and the friendly advice. | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | The chains lay better when in the right way. On '54 and up they go in from the bottom. I'll be damned. Never knew that... | | | | | Joined: May 2010 Posts: 89 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 89 | I'am under the inpression. The easyest way of insertion with out intanglement,is the proper mounting arrangement.
theres a tool for every job,and that tool is a hammer. it's easy to give advice if it's not your pocket book at stake. A well thought out plan,Is nothing. Untill exacuted twice.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | As, I said, the '54 and up chains lay right when inserted right. The bend of the hook makes them lay right. If you have repro hooks they may need to be bent to match original ones. Mine did. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Cletis, You seem to have these chains figured out. Do you have a tutorial on how to bend them or some good pictures and measurements for making them so they work right?
Mine came with 60d nails for hooks. I got them so they work but they don't lay right and have been rubbing the paint. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Sorry, I didn't take pics. I had a rusty pair of originals to work from. | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | Cletis isn't it an S-bend with a 90 degree twist? I'm not near my truck now or I'd go out and have a look. The 90 deg twist allows it to lie flat against the bed at the chain end, while hanging clear through the hole up top.
I got the rubber chain tube protectors that keep it from swinging against the gate frame and fenders, but I thought they were way too short to be fully effective. I added some bicycle tire innertube to bridge the gap between the rubber chain tube protector and the hook. Little damage now. (Sure wish the chinese would cut those things about 4" longer and allow US to trim them to fit! Cheapskates. grrrrr)
Bill | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | (Sure wish the chinese would cut those things about 4" longer and allow US to trim them to fit! Cheapskates. grrrrr)
Bill That's because we use US inches and they use metric.  | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Quite the question. I thought someone was going to ask what color of air was in the tire originally!! As to tail gate chains. Be different. Put one through from the outside and the other from the inside. | | |
