| | | Forums66 Topics128,068 Posts1,055,882 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#67328 10/18/2006 11:27 PM | Joined: Jun 2006 Posts: 17 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 17 | Ok, I know that my tranny isn't an oldie and if my husband finds out I am posting this I might hurt his male pride but we have a 1997 1 ton pickup with tranny problems. My husband is WONDERFUL with the older stuff but we are lost on the new stuff.
Sometimes, it seems when it is cold, it won't shift into overdrive. Then when it is warm or when it feels like it, it shifts just fine. It also will slip sometimes too. We both figure it is due to get rebuilt but am hoping there is a little trick we can try to keep it alive for little a while longer. Any suggestions or help would be apprecitated. Thanks! :confused: | | |
#67329 10/19/2006 12:37 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Debbie Jo, your problem could be as simple as a fluid and filter change, or as bad as a transmission rebuild. The 4L80E is a heavy duty electronically controlled transmission, the E.C.U. [computer] has to be able to communicate with the engine E.C.M. [computer] and all of its sensors, or problems like this may occur. I would take the vehicle to a shop that can download any codes from either computer, if there are no codes then I would take the vehicle to a transmission shop you trust and have them diagnose it, hope that helps. | | |
#67330 10/19/2006 3:56 AM | Joined: Jun 2006 Posts: 17 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 17 | I sure appreciate the feedback. We have changed fluid. We figure that is the next step to have the computer checked out but I just would love to get rid of it. I hate computers, sensors and all that junk. I wonder how difficult they are to rebuild. I have done a turbo 350 with help. I figure you would need a medical liscense to tear into this one.
Anyway, thanks so much. I guess I will just have to break down and get someone else to do it instead of us. | | |
#67331 10/19/2006 5:41 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | HY Debbie Jo, if it turns out to need a rebuild, they are not all that different to work on than the non computer transmission, just a lot of solenoids to control the functions. Cleanliness is the most important thing when rebuilding any tranny, good luck. | | |
#67332 10/19/2006 12:40 PM | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | | | |
