Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (cmayna, jay d, 2-Ton, 2 invisible), 44 guests, and 3 robots.
Topics128,009
Posts1,055,292
Members48,419
#673233 08/26/2010 3:28 PM
SPL
Offline
Does someone have a dignostic for dummies to check out the V.R. ? I have a '57, 235 with generator and the ammmeter needle stays centered and only momentarily jumps to the positive side for charging then goes bck to center and stays there.
SPL #673261 08/26/2010 5:37 PM
There's an extensive adjustment procedure in the 55.2 shop manual that you can link to in Tech Tips, but it sounds like maybe your system is operating normally. The main thing is - does your battery seem to be fully charged and are your lights nice and bright and not flickering?
Riding in the Passing Lane
Like Waldo say's it probably is normal. When the bat is fully charged there is no curent flow & the gauge stay's in the middle. If you turn on the lights It will go to discharge at idle & if you accelerate it will go back to charge & back to the center. A good test is to get a volt meter & put it across the bat. term. on the reg. & ground. Acel. the engine & it should read between 13.8 & 14.5 volts.
1972 Chevy c10 Cheyenne Super
