1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 27 New Guy | | New Guy Joined: Apr 2010 Posts: 27 | Does someone have a dignostic for dummies to check out the V.R. ? I have a '57, 235 with generator and the ammmeter needle stays centered and only momentarily jumps to the positive side for charging then goes bck to center and stays there. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | There's an extensive adjustment procedure in the 55.2 shop manual that you can link to in Tech Tips, but it sounds like maybe your system is operating normally. The main thing is - does your battery seem to be fully charged and are your lights nice and bright and not flickering? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Like Waldo say's it probably is normal. When the bat is fully charged there is no curent flow & the gauge stay's in the middle. If you turn on the lights It will go to discharge at idle & if you accelerate it will go back to charge & back to the center. A good test is to get a volt meter & put it across the bat. term. on the reg. & ground. Acel. the engine & it should read between 13.8 & 14.5 volts. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
