4 members (Robert Crandall, J Lucas, 1955 1 Series, Otto Skorzeny), 99 guests, and 2 robots.
Topics128,094
Posts1,056,465
Members48,443
Hello from England,
I am going to put a 350 into my Apache 10, I currently have a 235 in the truck, with a 3 speed manual tranny. I recently fitted the 235,sold to me as a "good one" ....smokes worse than the one that came out....great!
What parts will I need to change the motor?
I can get a bellhousing with the hydraulic clutch......my Apache has hydraulic clutch (1961)
I can get a manual flywheel.
What other parts am I going to need?.... is it a fairly straight forward job?.....
I know that I will need the V8 engine mount kit, and the exhaust will need to be modified.
Are there any other things I should be aware of???
Please let me know, all advice will be greatfully received.
Laine
Hello again,
Can you tell me if my flywheel/clutch assembly will fit onto a 350?
Thank you,
Laine
your best friend will be the shop manual for whatever year you have - no, the 235 pressure plate and disc won't fit the V8 flywheel
Hello again,
Any advice for this motor change?
Can anyone show me in a picture what the engine mounts for a V8 should look like in a 1961 Apache?..... are they still available?..... will I have to fit one of those crossmember motor mounts instead?
Please let me know, someone must have put a 350 into an Apache with a 235.
Laine
My friend has a '61 Apache with V8.
It has the horseshoe type front mount like this.
Steve
'49 3800
'52 3600
'57 3100
There are many options for motor mounts. check the speedway website, motor mounts is one of the popular searches there.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
