| | | Forums66 Topics128,091 Posts1,056,449 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 15 New Guy | | New Guy Joined: Dec 2009 Posts: 15 | Hello from England,
I am going to put a 350 into my Apache 10, I currently have a 235 in the truck, with a 3 speed manual tranny. I recently fitted the 235,sold to me as a "good one" ....smokes worse than the one that came out....great!
What parts will I need to change the motor?
I can get a bellhousing with the hydraulic clutch......my Apache has hydraulic clutch (1961) I can get a manual flywheel.
What other parts am I going to need?.... is it a fairly straight forward job?.....
I know that I will need the V8 engine mount kit, and the exhaust will need to be modified.
Are there any other things I should be aware of???
Please let me know, all advice will be greatfully received.
Laine
| | | | | Joined: Dec 2009 Posts: 15 New Guy | | New Guy Joined: Dec 2009 Posts: 15 | Hello again,
Can you tell me if my flywheel/clutch assembly will fit onto a 350?
Thank you,
Laine | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | your best friend will be the shop manual for whatever year you have - no, the 235 pressure plate and disc won't fit the V8 flywheel
Bill | | | | | Joined: Dec 2009 Posts: 15 New Guy | | New Guy Joined: Dec 2009 Posts: 15 | Hello again,
Any advice for this motor change? Can anyone show me in a picture what the engine mounts for a V8 should look like in a 1961 Apache?..... are they still available?..... will I have to fit one of those crossmember motor mounts instead?
Please let me know, someone must have put a 350 into an Apache with a 235.
Laine | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | My friend has a '61 Apache with V8. It has the horseshoe type front mount like this. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | .... are they still available?.... There are many options for motor mounts. check the speedway website, motor mounts is one of the popular searches there. | | |
