| | | Forums66 Topics128,174 Posts1,057,048 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 13 New Guy | | New Guy Joined: May 2010 Posts: 13 | I have not gone close up to see it, but a local man has a '54 short bed on a 1990 Suburban chassis. He says it was shortened 14 inches, but 12" would have been better.
I have not previously heard about doing this. Have you? | | | | | Joined: Jul 2004 Posts: 2,991 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,991 | If you get a chance, we'd love to see some pictures. | | | | | Joined: Apr 2000 Posts: 199 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 199 | Wasn't 90 Suburban still on the 73-87 style frame? If so, I would expect that there would still be width issues. He probably is saying 12" would have been better if he was measuring the stock wheelbase and didn't take into consideration putting the rear axle back the 1.5" it really needs to sit in the wheel wells. | | | | | Joined: Sep 2008 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 137 | Yes, the frame on a '90 Suburban is the same as the 73-87. In fact, they used the 73-87 style frames through 1991 on the Suburbans, Blazers and Crew Cab trucks.
