| | | Forums66 Topics128,078 Posts1,056,056 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | 235 motor, set the TDC, starts only with Choke and when I turn off the choke, engine accelerate/deaccelarates and pops thro exhaust. Feels like always running rich, idle screw and air mixtures screws has no effect. I checked the carb and set the float 1 3/4 as described in the shop manual and still runs rick and pops through exhaust. When accelerated pops through exhaust and carb.
Any ideas. Thanks in advance
Ganesh | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Is your accelerator working? | | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | Yes it is working Crenwelge
Ganesh | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Distributor advance weight spring broken maybe? | | | | | Joined: Jan 2010 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 126 | Sounds like it could be a vacuum leak maybe... | | | | | Joined: Jan 2010 Posts: 60 New Guy | | New Guy Joined: Jan 2010 Posts: 60 | Is your valve clearance correct can be that one of more of your valves do not sit well Jianis | | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | Ok I fixed the problem and it purrs at 500 rpm and no backfires at higher RPM
One thing was had gas pedal rod was stuck a little bit so always engine was running at higher rpms, fixed that and reset TDC, adjusted the timing with timing light not by ear. Then adjusted carb idle and air now it runs good.
Just to add note, 216 motor flywheel and bellhousing timing marks works good for 58 235 motor as I did a swap. They are all same since lot people said the timings may be different but today I set the timing with timing light and marks worked good
Sprayed carb cleaner no leakes around, put the vacuum gauage to wiper and showed in green zone in ~20 inches range.
Thanks for all the support help and you guys are awesome
Ganesh | | |
