1 members (baldeagle),
91
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 69 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 69 | I bought a CPP 5559MCA master cylinder bracket so I could upgrade to a dual reservoir master cylinder. I read about this bracket from Cletis' Tech Tip. I'm having trouble with the parts. Instructions show a Female clevis joint bolting up to the brake pedal, but I have a Male clevis joint. No long threaded nut to connect the two and use for fine adjustment. And the bolt to hold the clevis joint to the pedal arm is probably 1/2" too short, with no spacers to make things line up. Complete assembly No Clevis and Push Rod don't attach Don't align side to side either. Pedal bolt too short, no spacers. So I guess I have to go to Princess Auto to get a male clevis joint, and bunch of grade 8 bolts to see if I can make it work. I've read others report similar problems with CPP products. How difficult is it to ship the correct parts, and print accurate, clear instructions? Anyone ever tried to use the original master cylinder as a bracket only, and mount a small master cylinder on the back ? Check out part number MB15559. I like the idea of having a remote reservoir instead of trying to work through a hole in the cab, with all the dirt around the master cylinder reservoir. ABS Power Brake.com Master Cylinder using original for brake pedal bracket Appreciate your feedback and experience.
When God gives any man wealth and possessions, and enables him to enjoy them, to accept his lot and be happy in his work�this is a gift of God. He seldom reflects on the days of his life, because God keeps him occupied with gladness of heart. Ecclesiastes 5:19-20 | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | I bought a CPP 5559MCA master cylinder bracket so I could upgrade to a dual reservoir master cylinder. I read about this bracket from Cletis' Tech Tip.
So I guess I have to go to Princess Auto to get a male clevis joint, and bunch of grade 8 bolts to see if I can make it work. Looks like they sent you the wrong stuff. Did they offer to make it right? I've read others report similar problems with CPP products. How difficult is it to ship the correct parts, and print accurate, clear instructions? I just used one and the instructions weren't the best, but sufficed. I had to space the clevis a bit, but all in all, what they sent me bolted on easily and has worked well so far. Much easier than fabricating all that stuff. Price wasn't bad either. I like the idea of having a remote reservoir instead of trying to work through a hole in the cab, with all the dirt around the master cylinder reservoir. I made the hole big enough to work through.. http://img.photobucket.com/albums/v228/Avette4me/My%2058/Brakes/HoleforMasterCyl.jpghttp://img.photobucket.com/albums/v228/Avette4me/My%2058/Brakes/CoverforMaster-mockup.jpg | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | They shorted you a piece. There should be a union to join the clevis to the master cylinder rod.
I solved the mis-alignment this way: (from the tech tip)
"I picked up a 2" long 3/8-16 bolt, a nut and lock washer, all in Grade 8. I used the supplied washer and spacer on opposite sides of the rod end. I put my new nut and lock washer on one side of the pedal and the supplied nyloc nut on the other side. Now the bolt is tight on the pedal and the plunger goes straight into the master cylinder. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Wrong parts, they will send you new one's, good company. The female piece you are missing is called a rod end not a clevis. A clevis end is "U" shaped. I am fabricating my own remote reservoir system. +/- $15
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2009 Posts: 69 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 69 | I sent an email to their customer service dept. Said a replacement Female rod end, and new push rod would be sent to me. Haven't received it yet. I'll let you know when it comes in.
But I'm still thinking of adding an adapter plate to the back of my old M/C... New '74 Nova dual circuit M/C is $50. Should be just as effective.
When God gives any man wealth and possessions, and enables him to enjoy them, to accept his lot and be happy in his work�this is a gift of God. He seldom reflects on the days of his life, because God keeps him occupied with gladness of heart. Ecclesiastes 5:19-20 | | | | | Joined: Jul 2010 Posts: 14 New Guy | | New Guy Joined: Jul 2010 Posts: 14 | Excuse my ignorance but what is CPP in the way of parts? | | | | | Joined: Oct 2009 Posts: 69 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 69 | Classic Performance Parts They sell lots of upgrades for our vehicles. Regards.
When God gives any man wealth and possessions, and enables him to enjoy them, to accept his lot and be happy in his work�this is a gift of God. He seldom reflects on the days of his life, because God keeps him occupied with gladness of heart. Ecclesiastes 5:19-20 | | | | | Joined: Oct 2009 Posts: 69 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 69 | Finally got the new linkage parts. Still has a push rod that is too short for my deep bore 74 Chevelle dual circuit master cylinder. I made my own.
When God gives any man wealth and possessions, and enables him to enjoy them, to accept his lot and be happy in his work�this is a gift of God. He seldom reflects on the days of his life, because God keeps him occupied with gladness of heart. Ecclesiastes 5:19-20 | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Its hard for someone like CPP to know all the various OEM components their kits might be matched with, and since the needs of different truck owners vary it doesn't make sense to limit the options to just one master cylinder or a short list of possible masters.
Adapting the kit and instructions should be part of our expectations when tackling a project like this.
I know its frustrating and we always want the kit to fit exactly our individual truck and needs, but its not a realistic expectation.
I have the CPP bracket on my '55 1st Suburban. I had trouble with the alignment of the rod and ended up leaving off the retainer on the pedal pivot. Since both come through the floor and are on that pivot and attached to rods on the other end, they don't seem to move far enough for it to be a problem except in the occasional hard corner when the brake pedal will stick a little coming back up.
Not perfect, but I've been driving it that way since late 2002 and have been satisfied.
My next moves with this truck will probably include a firewall mounted booster and that will change the whole thing.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....while sharing experiences I can say that my booster/m.c./pedal & brackets bolted up just great on my 52 Panel. I got mine from PirateJack in Asheville,N.C. and it all worked very good. I did enlarge the top of the hole for the brake pedal but feel that was some error on my part replacing all the floorboards & and a little problem with crossmember was not PirateJacks fault. All their parts fit like peas in a pod! ...and more than a $100 less than the "usual" vendors we use. Just my "experience". | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I did the same upgrade from CPP had had no problems. They have always done me right and quickly made any necessary corrections. Great company.
~Jim
| | | | | Joined: Jan 2006 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 24 | I have their dual master cyl. and bracket, but used the original pedal bracket since I am running a 235 and T-5 combo. Only issue I had was that the mounting bolt heat stuck out too far from the bracket to allow the MC lid hold down to swing forward to fill the MC. pulled the bolt and ground down the head and it was fine.
| | | | | Joined: Feb 2010 Posts: 20 New Guy | | New Guy Joined: Feb 2010 Posts: 20 | bringing this back to the top... has anyone done this modification successfully to a '46 1/2 ton truck? i am in the process of correcting work from a previous owner... noticed CPP lists their dual MC bracket for 47-54 and 55-59 chassis. im not familiar with the differences between frames for 1946 and 47. thanks | | |
