1 members (Hanks custodian),
103
10
Mod | | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 18 New Guy | | New Guy Joined: Jul 2010 Posts: 18 | I was wondering how you can diassemble the healight switch? I've heard its this internal pin type and there is a button? Also I switched to a 1 wire alternator and now have no lights. Where to hook up the main power for the lights? This truck was lightly vandalized before I got it. It is chassis cab and had a huge flatbed on it. I put a regular one on. It has a 283 2bbl, SM420 tailshaft brake, and 5.14 in the back, dually. | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | It's been a while, but there is a button somewhere on the switch itself. Pull the knob all the way out, as like you are putting the headlights on, then press the button from under the dash, then pull the knob assembly out.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | the headlights are 2 wires that has thru the metal behind the grill thru a plug. then up thrue the firewall in the main plug on the drivers side. then to the fuse box- best i remember. good luck! i chuckled when i read "lightly vandalized". why in the heck do people do that! | | | | | Joined: Jul 2010 Posts: 18 New Guy | | New Guy Joined: Jul 2010 Posts: 18 | Ok, got it working now. This truck was bought new for a Tree service, and was sold in 1979 to a landscape company, then sold to a machinst, and then to me. This truck has 48K original miles. All reciepts of parts ('64-'05) were in the glovebox since I got it. Apparently someone was planning on pulling the engine at the machinist's. All wiring was unplugged or cut. Does anyone know how to adjust the tailshaft Parking brake on these? I also got a PTO setup on this. When I get it installed, is the box on the trans all I need? What gear do I put it in to drive it? | | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | What gear do I put it in to drive it? To operate the PTO you engage the clutch, engage the PTO, release the clutch. The PTO will be turning/operating. The PTO will work in any gear but I generally use it in neutral or at low speed. SimS | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Here's a link to 60-66 wiring diagrams, unfortunately the 64 isn't there. The 65 wiring diagrams are there, and should help. http://www.64moneypit.pages.qpg.com/6066chevytrucks/id81.htmlFactory manuals are available repo. You need the 63, and 64 supplement. Check the links. Welcome aboard! Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Jul 2010 Posts: 18 New Guy | | New Guy Joined: Jul 2010 Posts: 18 | Ok, got the wiring figured out now. How do I adjust the parking brake on the tailshaft? It will not work all the way back. Any suggestions? | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | hopefully no vandals crawled under it to do anything with the parking brake. if it just won't click might make sure teeth are clean and everything is lined up. if it will click but not hold there is a adjustment on the band, or might see if the lining is still even in there to hold. good luck. | | |
